Panasonic PT L501U Projector
Swapped power supply... and same issue... what next?
  • 563 Answers
Hi fccanova1973
Then the only other part that can cause this would be the Mainboard.
Posted on Apr 21, 2008
How to rest alamp hour on panasonic tv with a universl remote model pt 432-c14
Turn on the projector
MENU-
OPTION-
LAMP RUNTIME-
Press and hold the ENTER button for 3 seconds.
Turn off the power.
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 31, 2014 | Panasonic ET-LAM1 Projector Lamp for...
The projector would not turn on and had a flashing red light for the lamp. Knowing it was an older projector when we rented the building I purchased a new bulb for this projector. When I put the new bulb...
PROBLEM :-The power supply of the projector is faulty there is a transistor witch is switch 15 volts for the lamp drive board.
SOLUTION: Remove the upper cover with 6 screws back side of the projector.
remove main board and lamp cover with 7 screws.(show in the picture)
remove upper cover of the power supply and lamp drive unit with 3 screws.
remove power supply unit with 4 screws and 3 connectors and put face down on the table.
now you find the transistor no Q107 and replace with the transistor no 2SB710 is and surface mounted compunent(show in the picture)
fix it all as you open.
power ON the projector and enjoy
(doing very carefully This is a technical job)
Feb 05, 2011 | Panasonic PT-LB10SVU Multimedia Projector
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
Panasonic PT-LB10U do not work lamp ok ballast ok issue is with the power suplly that do not send 15v dc to the ballast need to fix the power supply it send 380 v dc to the ballast but do not have the 15 v...
You have to replace the transistor Q107 on the board ETXM519MBGB
this is pnp type but i can't find it on service manual.So if you don't like to make experiments replace the board.
Oct 21, 2009 | Panasonic PT-LB10VU Multimedia Projector
Panasonic PT L501u Replacement Lamp
panasonic projectors , even if the lamp has reached end of life gives u 10 minutes to reset the lamp counter
so when u replace a new lamp, go to options, lamp counter, reset & press stanby button for confirmation!
thats all the unit powers off & when u check the lamp counter , its shows 0
u r done!!!!!!
Jan 22, 2009 | Panasonic PT L501U Multimedia Projector
Panasonic PT-L501U
Hi BEEZELLE
Does the VGA input work ?
If not then the Mainboard is at fault and will need either repair or replacement.
May 11, 2008 | Sony VPL PX31 Multimedia Projector
Right , if the indicator light goes from Green to Orange when shutting down , it will be the Powersupply that is giving problems and not the Ballast.
Apr 17, 2008 | Office Equipment & Supplies
Ok , so the lamp is out then.
Before spending the money on a new Ballast.
Switch on the Projector while the top cover is off and check if all your fans are running.
The red light you see glowing on the Mainboard is quite normal.
Apr 17, 2008 | Epson EMP 720 Multimedia Projector
Hi there
Have you replaced the lamp ?
If you haven't - take out the lamp and chech for any irregularity on it - i.e. - discolouration , vein like looking marks ( black or white ) and also if the shape of the shaft is off.
If there is no visible damage it might be a faulty Ballast ( lamp's powersupply ) - especially if you cannot get it out of stanby once it has shut down.
Apr 15, 2008 | Office Equipment & Supplies
Panasonic PT-AX100
Hello
Check the process of Power supply and the outputs. powerup the projector the replace the faulty gear assy or repair the same.
viren
Rave Services India
Jan 04, 2008 | Office Equipment & Supplies
103 people viewed this question
k24674
jasbo
jasbo
