Question about Craftsman 19.2V C3 DRILL/DRIVER
How do you remove the chuck of 18 volt cordless drill?
Need to replace chuck
  • 518 Answers
Lock an allen key in chuck,,chuck has l/h thread so turn chuck anticlockwise to remove
Posted on Jul 07, 2010
3 Suggested Answers
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
mark24354
  • 776 Answers
SOURCE: How to remove a chuck from a DeWalt hand drill
Open chuck all the way (like for a large drill bit). There should be a set screw at the bottom (where you would put a drill bit). Don't turn too hard - it may be a left handed screw (I don't remember if it is a lefty for sure but try gently each way then with a bit more force each way until it moves).
Good luck.
Posted on Mar 19, 2010
My 18 volt dewalt cordless runs well except when I try to remove something with it. Reversing the drill makes my nutdriver bit fall out as it opens the chuck, so all removals have to be done by hand.
I would make sure that the bit is firmly installed in the chuck, you should hear clicking when the bit is tightening, this is the chuck locking itself on the but. and when going in reverse make sure you dont have your hand or have the chuck pressed against an object. If nether of these are the problem then there may be a problem with the chuck itself and should be replaced.
Apr 02, 2011 | Dewalt 18 Volt Compact Drill Kit
How to change the chuck on 18 volt cordless drills
Set the drill to reverse. Hold the chuck, press the trigger and open the drills chuck to it wide open position. Now,, take the correct size allen wrench and insert it into the back of the chuck to remove the screw. Turn the screw clockwise to remove it. Notice I said clockwise, just the opposite of what you might think. Hold the chuck with your hand or a pair of large vise grips and press the trigger to unscrew the chuck from the drill. Rotate it counterclockwise to remove it from the drill. Reverse the procedure to install the new chuck.
Mar 10, 2011 | Dewalt 18 Volt Compact Drill Kit
Chuck will not hold bits, How to change chuck
down inside the chuck theres a big flat head screw that should do it.
Nov 17, 2010 | Hitachi DS18DVF3 18 volt Cordless Drill...
Hi i broke the chuck on my 1/2 makita cordless
Put the biggest hex key you have in the chuck and tighten it then hit it clockwise with the spindle lock engaged a couple of times. The screw in the chuck will then undo clockwise and the chuck can be undone after by putting the allen key back in and unscrewing it anti-clockwise maybe with a light tap from a mallet.
Hope this helps
Jon
Jul 01, 2010 | Makita 6349DWDE 18-Volt Ni-MH 1/2-Inch...
How do replace a chuck on a black-decker cordless drill
you must open the chuck all the way and the screw is in the back inside the chuck this is a left screw which means its righty loosey and lefty tighty; unlike normal righty tighty and lefty loosey.
Mar 29, 2010 | Black & Decker 18 Volt Cordless Drill...
Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Aug 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Changing the chuck on an bosch 18 volt cordless drill
Inside the chuck is a left-handed screw. Either torx (star) or flathead, usually. When you get it out, take an allen wrench and (if you can tighten it up at all, tighten the **** out of it). If not, find an allen wrench, a tiny bit smaller than the space allowed. Now, get a nice big hammer. The chuck is right handed thread. And knock it, spinning the chuck off the spindle. May take a few whacks. Use the edge of a workbench to keep it stationery if need be. Lemme know. Please rate me
Jun 17, 2009 | Dewalt 18 Volt Compact Drill Kit
Bosch 18volt brute force cordless drill how do i remove chuck
Jan 31, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
Craftsman 19.2V C3 DRILL/DRIVER Logo
803 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
