Question about Umax Astra 3400 Flatbed Scanner
How do I remove and clean the glass? - Umax Astra 3400 Flatbed Scanner
    Genius:
  • 1,970 Answers
Mcdevito75 here, Check with your local Radio Shack, Staples for a product used to clean Scanner screens. I wouldn"t attemt to remove any portion of the scanner a s it could cause dammage.
Posted on Jul 07, 2010
How do I clean the inside glass on my electric fireplace
To remove any dust, simply use a clean, dry cloth to wipe down the interior. Gently dust any media such as logs or glass inside your electric fireplace as well.
Cleaning Steps
1.Disconnect from Power Supply Before beginning to clean your electric fireplace, turn the heater off and allow to cool completely. Always disconnect the electric fireplace from the power supply before cleaning.
2.Check the Electrical Components Check any wires and plugs to make sure that they are not worn or frayed. This is a rare occurrence, but can become a fire hazard if not addressed. If this happens, consult a professional to repair or replace before using your electric fireplace again.
3.Clean the Heater With a clean, dry cloth, wipe down the surface of the heater. Using the soft brush attachment of a vacuum cleaner, gently clean the heater outlets. This will remove any dust or debris from the heater and keep it running at top performance.
4.Clean Both Sides of the Glass Follow the instructions in your owner's manual for removing the front glass panel. Once removed, you can clean both sides of the glass. Do not use abrasive cleaners, as they will scratch the glass. Dust can be easily removed with a clean, dry cloth. Fingerprints or other marks can be removed with a damp cloth; dry the glass with a lint free cloth to prevent water spots from forming.
5.Dust the Interior Dust may accumulate inside your electric fireplace, like any other unit in your home. To remove any dust, simply use a clean, dry cloth to wipe down the interior. Gently dust any media such as logs or glass inside your electric fireplace as well. When you are finished, place the front glass panel back onto your fireplace following the instructions in the owner's manual.
6.Remove the Soot Just kidding! You never have to worry about dirty, grimy soot with your electric fireplace. Instead, just relax and enjoy!
Nov 14, 2017 | Miscellaneous
How do i remove the glass from the door
The oven door glass panel is a sealed unit that is not intended to be removed for "cleaning". The unsightly residue between panes accumulates because the metal seal expands while the oven is heating.
Jul 30, 2016 | Ovens
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
How to remove glass on oven door for cleaning,zanussi instruction manuals
Oven door glass is not designed to be removable for cleaning.
Jul 19, 2014 | Zanussi Ovens
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
How do you clean inbetween the oven glass door?
To clean between you need to remove one of the pieces of glass...usually the inside is the best....
There are a few screws on the inside of the door theat hold the frame, which holds the inside glass...
remove the frame and carefully remove the inside glass... clean the inside of the outside glass, then clean the inside of the inside glass and then reinstall the froame over the inside glass...
Now you have a clean ove glass again...
heatman101
Nov 16, 2010 | Microwave Ovens
Need to clean the under side of the glass. Need
I found a service manual on-line that showed the method for removing the glass on the scanner.
Nov 16, 2009 | HP Office Equipment & Supplies
Glass Door stain
you can clean it but its not easy u have to remove the door put it on the floor remove the screws from the side and the bottom the glass should slide out then then u remove more screw to get the other piece of glass then u clean it and put it all back togather
Mar 16, 2009 | Kitchen Ranges
Cleaning the Flatbed Glass
We cannot clean inside the flatbed scanner glass, it is not a removable part.
Jun 06, 2008 | HP Photosmart C6100 All-In-One Printer
Smudges on scanner glass inside unit
hi im jules_09,the scanner glas should not be remove from the unit because if it is remove you might get a error code,so just get a soft cloth or a any kind of tissue and table tissue will do then apply a glass  cleaner on it then gently rob it on the scanner glass until the glass is clean just make sure the unit is off and ulplug.if the scanner glass is cleaned
Oct 13, 2007 | Office Equipment & Supplies
Umax Astra 3400 Flatbed Scanner Logo
118 people viewed this question
Top Umax Office Equipment & Supplies Experts
Ricky Ostrom
Ricky Ostrom
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
