Question about Microsoft Computers & Internet
Delete key doesn't work
Computer delete key on keyboard doesn't work . delete key in numbers section does not delete character and adds a period . As an example, if I delete x from example, I get e.xample (Windows 7)
  • 20 Answers
The ". del" key on the Numerick KeyPad will delete if you use the SHIFT key at the same time. It is easier to use the DEL key on the main keypad.
Posted on Jul 10, 2010
How do you type characters when setting up your email etc.
You will discover the @ character above the apostrophe on the r/h side of the keyboard. Press and hold down the shift key and all the dual purpose keys will become the alternative characters as printed on the keys.
The dot or full stop, or period as the Americans call it, is at the bottom r/h of the keyboard and the shift key isn't needed.
Apr 17, 2018 | The Computers & Internet
What is wrong with my laptop? It is as if the shift key is stuck
Go into device manager in windows and delete it and reboot. If it comes back when it detects the keyboard and it works then it was a driver, if it does detect it or it wont work correctly then it is a bad keyboard. You can also try a plug in keyboard to see how it behaves, ps keyboards are not that expensive.
Oct 11, 2015 | Toshiba Computers & Internet
When pressing number on laptop its showing characters
From your description I must assume that if all other keyboard functions and keys work properly then the keyboard is faulty. For the number keys to print the upper case characters shown on those keys requires a shift key to be depressed or stuck. If all other keys work properly, replace the keyboard. Otherwise look for a stuck shift key. I have found keyboards for sale on Ebay.
Jun 19, 2014 | Lenovo ThinkPad Edge E430 Laptop Computer
Computer doesn't recognize ez eyes keyboard
unplug the keyboard, go to the manufacturers website and download and install the drivers, plug the keyboard back in.
If that doesn't work
check your device manager and see what keyboards are in the keyboard section. delete anything but the hid keyboard device and the standard ps2/2 keyboard from the keyboard section. repeat the first set of instructions
if that doesn't work either
take the keyboard back it is most likely faulty
Aug 25, 2012 | Toshiba Computers & Internet
A few keys on my Acer 4420 are not working properly and I have no idea as to why. The keys are my o, p, l, ' and period keys. When I do use them they type out random characters. My o keys types out i75`,...
If a neighbor will let you,disconnect their keyboard and try it on yours.If it works normal,the problem is the keyboard.They are fairly cheap to buy brand new.If it does not go away,something is wrong,most likely the IC which interprets the keyboard signal and converts it to letters.It sounds most likely to be the keyboard because it is a few characters consistently.Perhaps something was spilled in that section as they are quite close together.Good luck,Greg
Oct 30, 2010 | Acer NSK8458AN Keyboard
Characters dont match keys Choose " key and get @ and vica versa???
Goto the control panel, keyboard and choose US 101 keyboard
Sep 02, 2009 | Computers & Internet
My keyboard will not delete the character after the cursor location with the insert key???
You are correct. It deletes the character the cursor is on. Unclick insert and use the delete key to delete characters after the cursor.
Jul 11, 2009 | HP D8597A Keyboard
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
XPS One Keyboard's Characters not functioning
Try to re-sync the keyboard to the computer. Here’s the procedure:
1) Turn the computer on.
2) Turn on the keyboard
3) Press the sync button on the rear of your computer’s left speaker.
4) Press the sync button on the keyboard. ( I believe it’s on the bottom of keyboard)
The sync button has a symbol next to it, (2 arrows going in clockwise direction).
Ensure that the keyboard battery has not run low.
If that doesn’t work, look for a Bluetooth icon in the lower right hand corner of your desktop and double click on it to open the Bluetooth configuration utility. See if there’s a configuration file for the keyboard. If there is, delete it and then re-detect Bluetooth devices.
Hope this helps.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 20, 2008 | Dell Inspiron XPS Gaming Mouse Pad KU170
Toshiba Satellite Latop - Keyboard problem when entering password
my email add is kant_rai@yahoo.co.in
i need to driver for my laptop model no.is
A60 satellite
can you suggest on my email add.
Mar 31, 2008 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
439 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
