Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Telephone says seaching while in base wheentrying to dial out it says out of range
    President:
  • 567 Answers
Hi there, that mean your phone signal is very weak,you should check the antenna for sign of damage {if it has any}, and you should replace the antenna because its not working.
Posted on Jul 07, 2010
I had the same problem until I removed the plastic protective piece that was covering the black circle that says "6.0". That must be the antenna. Problem solved and phone is working well.
Posted on Jul 15, 2010
Magicjack problems
If the telephones work without MagicJack connected, you have your answer. BUT, the "no power at base" message means just that. Find out why and fix it. The loss of dial tone may be because the telephone system detected a problem and disconnected service until it is resolved.
Dec 03, 2013 | Computers & Internet
Lost phone manual, uniden d2997
I have a standard trouble-shooting routine for cordless phones. 1) Remove the battery from the handset (from all handsets for a multi-handset version). Then unplug the power cord from the base and wall outlet and also remove the telephone cord. Wait a few minutes and then reconnect the power and phone line cords. Reconnect the battery (ies) for the handsets. Make sure this connection is tight. Then make sure that the battery is fully charged (15 hours before first use) and register the handsets if needed. This is done by putting each handset onto the base in order for the D2997. Wait about 30 seconds for each one until you see the Handset Registered message. Make sure that you are within range of the base.
Next try a different telephone (RJ-11) phone cord between the base and the wall jack. Also check if the power adapter for the base is warm. For the next set of tests, I like to use an old corded telephone. Using a different phone, check if you get dial tone at the jack. If there is a dial tone, then the problem is with the Uniden phone. If the above trouble-shooting didn't help, then contact Uniden. These phones aren't meant to be user serviced.
If you do not have a normal dial tone, try another jack on the same telephone line. If there is dial tone at another jack, then you have a problem with the first jack. Otherwise find where your telephone service comes in. If you have a fairly new service, you'll find an RJ-11 jack. Plug your test phone into the jack and test for dial tone. If you have no dial tone or can't test your line, call your phone company. They will fix any outside problem for free. If it is an inside wiring problem, look at the visible wiring and determine if the wires are damaged. Open the jack (if only one is bad) and check for loose wires. There are two types of jacks. One secures the terminal wires with screws and the other uses a punch-down jack. For the screw type, strip additional insulation from the conductors, if needed, and then reconnect them. For the punch-down type, you will need the punch-down tool. It is available at many hardware stores in the wiring section. Use this diagram to check your jack wiring: http://www.lanshack.com/wire_phone_jack.aspx . If you can't see an obvious problem with the wiring, you may want a professional to deal with the wiring in the wall. Your telephone company will do this for a fee.
Uniden has the manuals for their DECT phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manual for the D2997 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D2997om.pdf .
I hope this helps.
Nov 26, 2011 | Uniden Lands Phones
I replaced my desk phone with a wireless and I lost dialtone on all the phones
Are you saying you have a wireless desk cell telephone? Or is this a regular land line telephone with a wireless hand piece? If it is a cell phone with no dial tone, you must see your service provider - this is HIGHLY unusual. If this is a land line telephone with a wireless hand piece - be aware that the dial tone cones from your base transmitter, where ever it is located, (Normally this base should be withing 300 feet of the hand piece) and that base unit MUST be plugged into an active telephone outlet. In the USA, the standard jack is an RJ 11. I suggest you take your old telephone and plug into the outlet where your new base unit is located. Do you get a dial tone? (proves the line is good) Check all wiring - same type of contacts (for your country)? Still no dial tone? Take it back to the store and get them to demonstrate its operation for you - does it work at their store? ... if not, get a new telephone or an adjustment.
Jun 04, 2011 | Cell Phones
Phones show line in use. Can not find a phone where this is the case. What do I do?
This indicates an off hook condition of the telephone line, to test it you could disconnect the telephone cable from your wireless system base and connect to it a standard wired phone, if you have dial tone and can make and receive calls, the line is OK and the failure is at the base of your wireless telephone system, if you don't have dial tone with the stardard telephone there's a telephone network failure (the telephone wall plate, internal or external cables, etc) and this should be reported to your phone company to be fixed.
Mar 01, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Searching and out of range message keep appearing. Can't dial out or receive calls Uniden Dect 6.0 (both phones) Tried to register base but unsuccessful.
This is because of the following reasons
1.The handset is far away from the base unit.Try to bring the hand set near the base unit and try.
2.The base unit is not plugged in to the power supply.Please check it.
Thanx
Jul 27, 2010 | Uniden DECT 6.0 Cordless Telephone...
No dial tone ,gets incoming, but cant hear anything, they cant hear me
Generic answer
You MUST get dial tone to talk or listen. Your base may ring but this may be unrelated to the telephone signal.
Check all wires and all settings. Are yoju certain your hand set is a member of your telephone group?
Sep 23, 2009 | Uniden DECT 6.0 Cordless Telephone...
I have an agere modem that came with toshiba satellite laptap the modem is set for US standards I am currently based in Greece -- do i need an initialization code to get it working?
You don't need to provide initializing code based on the country. Create your new modem connection using new connection wizard. Provide it with username, password and telephone no. to dial. Select your agere modem to use for dialing. It should work. If it not contact your telephone service provide to know about any initialization code needed to dial and connect into their network.
Aug 04, 2009 | Computers & Internet
Message reads: "Check tel line"
You can remove your telephone line from the base unit and fix it to stranded telephone unit and hear the dial tone.If it heard then some inductor or else part may be broken inside the base unit due high current surge.If the dial tone didn't heard from the other phone also check for the corroded line cord or modular box fault with the tel line.There should be 30 Volt-50Volt D.C.Voltage at your wire ends.
Rana.rishanranatunga@gmail.com
May 18, 2009 | Panasonic KX-TG1033S Cordless Phone
GE 2.4 GHz cordless telephone problem
Hi there, maybe I can help;
Is the phone base plugged into an switched outlet and is the switch off?
Let me know if I helped
Jan 06, 2009 | GE 21008GE2 Dual-Handset Cordless...
Model 25922 5.8 GHZ Cordless phone with one main phone and two extras
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ge Telephone Solutions
Handset can not link.
• If any handsets become inoperable, place it on the main base cradle for 20 seconds to re-register.
No dial tone
• Check or repeat installation steps
• Make sure the base power cord is connected to a working electrical outlet.
• Make sure the telephone line cord is connected to the base unit and the modular phone jack?
• Disconnect the base from the wall phone jack and connect another phone to the same jack. If there is no dial tone on the second phone, the problem might be your wiring or local service.
• The handset might be out of range of the base. Move closer to the base.
• Make sure the battery is properly charged (for 16 hours).
• Ensure the battery pack is installed correctly.
• Did the handset beep when you pressed the TALK/CALL BACK button? Did the in use indicator come on? The battery may need to be charged.
http://www.home-electronics.net/ge/pc/IB/25922GE2_IB.pdf
Sep 02, 2008 | GE 26998GE1 Cordless Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
784 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
