Question about Asko T701 Electric Dryer
Asko T701 electric dryer
Dryer just quit working as if the power had been shut off.
Yep me too found the fuses burnt out just replace and its working again.
Posted on Sep 17, 2008
Check the two fuses on the back. I had one burn out on me. Also there is a reset button on the back in the very centre (it is a rubber button).
Posted on May 08, 2008
Whirlpool gas dryer suddenly quit working. Light indicators on, so I do have power
Of course, check the lint screen for buildup. Also, make sure the vent (duct) that goes from the dryer to the exhaust is not clogged anywhere. Most modern dryers will shut off if they are not ventilating properly as a safety feature.
Dec 22, 2017 | Whirlpool Dryers
I cannot get my dryer to quit reading er68
Good Afternoon Friend,
I understand your Frigidaire dryer continuously shows an ER68. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Dryers
Replaced the element on dryer and still wont heat but will spin and washer had quit working when old element went out
I understand the washer and dryer of your Frigidaire laundry center, model# FEX831CS, are both giving you troubles. I suggest resetting your appliance, be either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FEX831CS Top Load Stacked...
Neptune dryer 5500 no power
This dryer has 2 thermal fuses. One next to the control stat on the blower housing and another on the heater element. You could quite possibly have a bad blower wheel or simply a lint build up cauing over heating. To get inside this dryer you remove the door first. The you can remove the front. Once that is removed you can pop the top and get the front shroud off. You cannot work from behind.
Sep 17, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Dryer is not heating. where is the heat sensor on DLE5001W
On a gas dryer the gas assembly is simply powered up by a sensor on the blower housing. If heat is called for from upstairs the power flows through the bimetal mounted on the blower housing. Here is a simple bi-metal: themobilian_2460.jpg
See the 4 wires? 2 of them wires operate a small heater inside the control. when it gets heated it shuts down faster for permapress and knits. Next to the control is a fuse on most models as seen here:
That fuse blows if the air temp exceeds 350f. That control thermostat at its hottest setting of cotton shuts down at 160f. It ramps back up at 105f. and continues to send power to the gas assembly till it feels 160f and then it shuts down. SOOO.. if we have a good fuse and a good thermostat 120 volts should get to the gas assembly if heat is needed. The gas assembly has a flame sensor which detects the heat bouncing off the ignitor. An ignitor to light off the gas, and a pair of holding coils. The whole gas assembly is energized at one. But them coils will not supply gas until the ignitor drops out if the circuit. To do so the flame sensor bi metal must shut down the power to the ignitor and that frees up the power to charge them coils and yank open the valve. The gas hits the ignitor and whoosh we have fire in the hole. It takes literally no time for the temp to reach 160 in the blower housing and so the power is removed from the gas assembly and the dryer tumbles onward absorbing the heat till the temp drops down to 105f and that control once again powers up the gas assembly. If your flame sensor is working and shutting down the ignitor and the heat works once or twice but quits then them solenoids are getting hot and quitting because they are old and weak. Replace em and party on.
Jun 18, 2011 | Whirlpool LGQ8000JQ Gas Dryer
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
Nov 24, 2017 | Kenmore Dryers
Dryer just quit running. power cord was replaced
If you have a fuse box in your house I would check the fuses for the dryer. The dryer runs on Two 30amp fuses.
If your house is on breakers. Shut the breaker off for the dryer and turn back on and test.
Hope this helps
Dec 31, 2009 | Dryers
Dryer quit working - will not do anything when "start" button is pressed
It would help to have the model number. the model number is on the front panel that the door shuts to. Have you checked your breaker? If your breaker is fine and you are getting power to the machine write back with your model number and I will try to help.
May 12, 2009 | Dryers
Dryer quite
my dryer worked fine before xmas but washed a load of clothes and temped to put clothes in dryer and put it on right settings and pushed button to start it and nothing. We tried the breaker and shut everything down for about 5mins. and started it back up and tried the dryer again and still nothing had friend look at it and looked online and I think it maybe the start button myself.
Dec 27, 2008 | Dryers
My Kenmore series 80 dryer quit heating. It was intermitent for a few days then quit. I checked the inspection window and didn't see any light. The gas it on and it seems like there is a "click" after I...
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse.6aed02c.jpg If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks.
Dec 22, 2008 | Kenmore 659 Electric Dryer
Asko T701 Electric Dryer Logo
313 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
