My hisense tv wont power on the red power light comes on but as soon as you try using the remote or side buttons the blue light flashes and then powers off
  • 367 Answers
SOURCE: TV won't power on.
Open the back of the TV,and look at the can shaped items on the boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Posted on Sep 09, 2008
SOURCE: when I push the power button, the blue light comes on but tv doesn't
It is the capacitor. It is really easy to fix, and it will cost you about $4. The capacitor is on the power board and it looks like a small battery. The bad capacitor will have a small bulge on the top, the good ones will be flat on top. You can buy them at Radio Shack. Just look on the side of the capacitor to see which one you will need. If you need any further info I would by glad to help. I have a 40in polaroid that this happened to and it works like a dream now.
Posted on Nov 02, 2008
ginko
  • 19396 Answers
SOURCE: HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
  • 11 Answers
SOURCE: Hisense TL2020 - Won't come on.
Lay unit flat on table, remove stand and rear cover. When you remove back, you will see a power supply board in the middle of the set.There are (3)1000mfd @25 volt electroltics and (1)220mfd @16 volt electrltyic that have to be replaced to return to normal operation. This is not something to try if you are a novice as you must observe polarity when installing these caps. But this repair WILL return set to normal operation.
Posted on Aug 08, 2009
  • 257 Answers
SOURCE: wont turn on
The power supply board has been defected. Replace it with a new one.
Posted on Aug 18, 2009
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
HL32V86 Hisense 32' stuck on standby wont turn on it seems screen stay black
Call the HiSense tech dept. You can find the number on line and they will tell you how to fix it or you can try using the remote and go to settings and see if you can fix it that way. Also the manual for this tv should be available online as well.
Jan 03, 2015 | Hisense Televison & Video
Why wont the flashing red light go away and switch on my 32 inch led hisense tv
It could be your remote control batteries are dead? Try to manually depress on/off switch on TV.
Dec 03, 2014 | Hisense Televison & Video
Hi my hisense tv won't turn on. The power is connected as the red light shows on the tv and and the blue lights light up on the side panel when I press the buttons- but the picture does not come on. It...
tv's without on switches has the same problem consider the signal to your tv from the remote and please keep the life span of your tv by switching it off completely.
Jul 14, 2017 | Televison & Video
I have a new 42"
I'd tell you how to repair it, but it'd void your warranty, and I never advise anyone to void their warranty, so I suggest you take it back and get it fixed or replaced under warranty.
Cheers!
Mar 15, 2011 | Televison & Video
Hi, We have a 42" hslc10668phz
generally when you get a constant green light all is ok. these different lights indicate different problems within the tv. so the pattern of lights you mention suggests there is a fault of some kind (is there a troubleshooting section in your manual)? either way it needs to be looked at.
Nov 28, 2010 | Hisense Televison & Video
Hisense tl2020 will not power on
power supply issue..may be some bad capacitors simply replace them....dada....your prob solved
happy to help
Aug 18, 2017 | Hisense TL1700 17 in. LCD Television
Hisense LCD Tl2020
I, also, have the Hisense LCD 1504 and cannot turn it on with the original remote. I have to use the ON button on the side every morning. You have to hold this button in for a while then wait a while and presto, the blue button shows on the front and the picture comes on. If it fails to work the first try, just try try again. It does work for me this way. We had this same experience with the TV in our room at a Hotel where we were on vacation and the TV worked fine when we turned it on using the side ON button. It just takes a while for the picture to appear. Hope this clue will help someone.
Sep 16, 2008 | Hisense LCD1504 15 in. Television
Hisense remote does not work with hisense tv
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Apr 29, 2008 | Televison & Video
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
Electro Med Services...
