Question about Homelite Garden
Is there a fuel adjustment on homelite 25cc string trimmer ut20738?
SOURCE: Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
Posted on May 16, 2009
#1 Taper
  • 1040 Answers
SOURCE: homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Posted on Jun 19, 2009
  • 508 Answers
SOURCE: Homelite Trimlite String Trimmer. String won't advance on tapping
remove assembly clean with soap and water and toothbrush(make sure when you dissasemble make notes of how to put back together!)Check spring make sure not broke or distorted-oil with silicon oil(walmart sells or auto parts store)reassemble reverse of dissassemble!!! hope this helps you!!!!
Posted on Jun 22, 2009
moretons
  • 155 Answers
SOURCE: Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
Posted on Jul 26, 2009
bbap
  • 71 Answers
SOURCE: i have a 25cc homelite weed trimmer.... the fuel
You will need the correct size fuel line first. Follow this:
1. Remove the old filter/weight from the fuel tank.
2. Take a new fuel line piece about 8 inches long and cut about a 45 degree angle cut on one end.
3. Lightly moisten the cut end of the fuel line and insert it into the tank from the outside, pushing it in while turning as far as possible.
4. Use a needle nose plyers to reach in and pull the line to the fuel line cap. Cut the line and replace the filter.
5. Pull the line back the way you put it in leaving about 4 inches within the tank and re-attach to the carburetor or primer bulb (depending on the actual model/age)
It will work, but it is extreemly important to have the correct size fuel line to work with.
Posted on Sep 27, 2010
How do I change champion strimmer cord
this is the pdf user manual for it
Champion Strimmer Manual - 64.140.158.30
64.140.158.30/champion/champion-strimmer-manual.pdfChampion Strimmer Manual - 64.140.158.30 homelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s manual your manual ...
Jul 17, 2016 | Garden
How to replace the fuel tank
308181004 Homelite Ryobi String Trimmer Fuel Tank ...
www.amazon.com > ... > Replacement Parts
Amazon.com, Inc.Amazon.com: 308181004 Homelite Ryobi String Trimmer Fuel Tank replaces ... Ryobi CS30 & Homelite C300 Trimmer Replacement (2 Pack) Air Filter # 98760-.
Oct 07, 2015 | Garden
Poulan p2500 carb adjustment
Carb not set correctly. Screw down idle an fast run screws an then reset. Sometimes fuel gets clogged an needs adjusting
Jul 04, 2014 | Poulan 25cc 2-Cycle Gas Powered String...
How do the fuel lines hook up
I made a video of changing the fuel lines on my Homelite 25cc. Homelite Tune Up
Jun 28, 2014 | Homelite Mighty Lite Lawn Trimmer
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
My homelite string trimmmer will not run when choke is run position. it will run, but not at full throtle, when choke is set between full choke and half-choke.
you've got a fuel system issue , most likely carb problem, if this a newer trimmer it will likely need the carburetor replaced or adjusted, also check for cracking fuel lines or signs of old fuel varnish in the tank
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Was given a homelite zipstart versatool string trimmer (25cc). what is the proper gas to oil ratio for this tool?
between 32:1 and 50:1 should be OK.
The best bet is to buy the premeasured 2 cycle fuel/oil mix in the bottles. They come with 8oz for a gallon of fuel.
Sep 23, 2009 | Garden
32 cc string trimmer will not run
It sounds like you need to adjust the fuel mixture screw in the carb. To do this, while it is running adjust the screw in either direction until it runs properly without the choke.
Sep 10, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
75 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
