Question about Janome Magnolia 7330 Sewing Machine
Newly bought Magnolia 7330 and the needle thread keeps breaking. I took it back to the place of purchase and they said it is working fine...watched me thread correctly. I've changed thread, needles and bobbin and the thread keeps breaking. Please advise.
This sounds silly, but I have the same machine and it kept happening to me too. Here's what I was doing wrong: When I thread it between 6 (thread take-up lever) and 7 (lower thread guide), the thread was being left exposed on the face of the machine instead of falling into that little **** of a crevice. One I figured out to stick it in the **** of the crevice, all was well. Try that -- and good luck!
Posted on Oct 17, 2010
Magnolia 7330 bottom thread is loose;re threaded several times;cleaned bobbin case;re threaded bobbin; new needle; frustrated;any ideas???
Have you tried the tension tips in the owner's manual? Be sure to ALWAYS RAISE the presser foot when threading the machine. There is a bit of a tug of war between the top and bobbin threads, so if the bobbin thread is too loose, try tightening the top tension so it will pull the bobbin thread up.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiQ4P73ncvWAhUP_mMKHaDjAacQFggmMAA&url=http%3A%2F%2Fjanome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fcomputer-models%2Finst-book-7330-engspfr.pdf&usg=AOvVaw3JQBPBb47hB9Uk_eCvDK30
Sep 29, 2017 | Sewing Machines
Upper thread has a loose stitch once in a while
check that bottom and top threads are the same quality and as well I would change the needle as a first port of call ...good luck
Sep 09, 2014 | Janome Magnolia 7330 Sewing Machine
My janome magnolia was working just fine and then all of the sudden the bobbin thread keeps knotting up. i've gone over all troubleshooting, cleaned out the lint, replaced the bobbin - all to no avail......
This happened to me on several occasions and finally one service tech told me not to use the needle down auto button. Instead when threading the bobbin just move the wheel toward you slowly until the thread catches.
Jul 08, 2014 | Janome Magnolia 7330 Sewing Machine
After 2 stitches needle is caught in ball of thread
More likely, you forgot to hold the bobbin and top thread ends together behind the presser foot when starting a seam. See: http://www.picturetrail.com/sfx/album/view/22521551
Feb 03, 2014 | Janome Magnolia 7330 Sewing Machine
After 2 or 3 stitches needle gets locked with balled thread
Lint and or thread has collected behind or under the bobbin. use a q-tip (cotton) and swipe out and around the bobbin and bobbin case. Use a can of air and blow out and around the bobbin area. Remove the spool thread from the machine and rethread the spool and bobbin thread in machine.
Machine eats bobbin thread
computerized so could be anything
tension or sewing action parts needs a service
Apr 28, 2017 | Janome Magnolia 7330 Sewing Machine
The thread is not straight when I sew
Puckering can be caused by wrong size needle/thread combo. Tension issues... improper threading. Check these first.
Dec 02, 2012 | Janome Magnolia 7330 Sewing Machine
Needle screw won't stay tight and needle comes out
the screw & the needle clamp may have to be replaced
May 11, 2012 | Janome Magnolia 7330 Sewing Machine
I have a Janome Magnolia 7330. The bobbin thread will not be drawn up.
The easiest solution would be to change your needle. They do wear out, get bent, etc, and that makes it difficult for them to pick up the bobbin thread. If you did just change the needle, there was a hint here on FixYa about being sure to face the needle correctly. If you feel the needle, there will be a flat side and a curved side. Check your owner's manual to see which side should face which direction.
Nov 29, 2010 | Janome Magnolia 7330 Sewing Machine
Janome Magnolia 7330 Sewing Machine Logo
268 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
