Question about Concord Fans (52PMB5WH) Ceiling
My ceiling fan won't go to high speed. What's the problem?
My Fanimation Islander FP320 stopped working, I've replaced the wall switch but fan won't spin and lights won't dim.
Check to make sure your fan is set on the high speed & the light is at the on possition with the pull chains.
Jan 01, 2013 | Fanimation FP320OB The Islander® FP320...
My tommy bahama ceiling fan won't reverse using remote
I have the same issue. My ceiling is 14 feet high and no clear easy way to get the fan down. Any other suggestions??
kmeyer6051@gmail.com
Nov 11, 2012 | Tommy Bahama (61092-45696) Ceiling Fan
The pull chain on my Regency ceiling fan has 4 positions, but the speed doesn't change: it runs on high speed for each of the first 3 positions, and then turns off at position 4.
mcdevito75 here Chances are the switch to change the fan speed is faulty, contact Ellington or see any store that sells ceiling fans for replacement switch if you can get one.
Jul 23, 2010 | Ellington REG52ABZ5LKRC Regent Ceiling Fan
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Oct 27, 2008 | Casablanca Fan Bel Air 3811T Ceiling
Ceiling fan woobles on high speed
Turn off fan, then check to see that all of the blade mounting screws are tight. (check blade to blade arm and blade arm to fan body screws/mounting mechs.) If none are loose, you can purchase a blade balancing kit from most hardware stores, including Home Depot and Lowes. Let us know if this helps or the cure you come up with.
Aug 23, 2008 | Hampton Bay 24002 Ceiling Fan
3 speed ceiling fan
I could not understand that "all the three positions are on high speed and off" ? How can be it possible that all the (three) positions give high speed and at the same time no speed (off)? Please explain.
 What I feel that the speed controller be in series with the fan. "in series" mean that the wire should come from phase or line, go to the speed controller , then go to the fan, then finally go to the neutral point. This completes the circuit.
 I will be happy to know more about this if it could not solve your problem.
Nov 28, 2007 | Westinghouse Turbo Swirl 78145 Ceiling Fan
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Concord Fans (52PMB5WH) Ceiling Logo
964 people viewed this question
Top Concord Fans Dryers Experts
jdthefixer
Tom Chichester
Ken B
Ken B
Are you a Concord Fans Dryer Expert? Answer questions, earn points and help others
