Question about Belkin (F5D7230-4) Router (587009)
I sent my lap top in for fixing so I got it back and I am trying to connect to internet and it states it needs a WEP or WPA Network Key address to type in can you help me with this? my other email is djflorek@peoplepc.com and I can provide more info after you contact me...Thank you
  • Computer Expert Jul 07, 2010
    Sure, please let me know the manufacturer name and the Model # of the Router to assist you better.
    President:
  • 1,768 Answers
1. Your router is the issue. It is asking for the WEP password or Network Key.
This is set up in the Wireless router.
You either know the password or have it written down.
If you are the administrator of the the router and don't remember the password or user name you will have to reset the route to factory default settings and go through the setup wizard and choose and create and save a new user name and password / WEP/WAP key. Consult your router cd for the instruction set. It will walk you through.
Posted on Jul 08, 2010
Motorola SBG901 installation CD on Vista 32 bit HP lap top error states "No wireless network adpter could be found please insert." Windows 7 laptop connected with no effort through the wireless...
it is a modem for cable. If you want to run your laptop you need the wep or wpa encryption key that is in the wireless 802.11 b/n/g part of the modem.
on the working p.c go to 192.168.1.0 in internet browser
type in user name of admin
type in password of motorola
do not change the settings as stated in the link below
just find out if ssid is broadcasting and what wi fi security is in use and what the encryption key is
http://setuprouter.com/router/motorola/sbg901/wifi.htm
https://kb.netgear.com/95/Configuring-your-wireless-connection-using-Windows-Vista-Wireless-Zero-Configuration-or-WLAN-AutoConfig-utility
Nov 28, 2017 | Computers & Internet
Describe your NetGear Problem Cannot get Apple on line. Need to get WPA key? Comcaast states must go through you to get WEP key or password
I understand that you need to check the security key so as to connect the computer with the router's wireless network.
In order to get this key we need to login to the router's page using any computer which is physically connected to router. Please follow the steps on a computer connected to the router so as to check the network key:
1. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
2. Access the router's GUI by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
4. Click on Wireless Settings (under Setup) from the left menu.
5. Check if WEP (Wired Equivalent Privacy) or WPA-PSK (Wi-Fi Protected Access Pre-Shared Key) is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase (or network key).
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the router's wireless network.
Mar 21, 2011 | NetGear WNR2000 Wireless Router
Stating no access point for internet
try to trouble shoot. If what i have provided below doesnt solve the problem let me know and i will assist you from there. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Jul 20, 2010 | Nintendo Wii Console
I CANT GOT THE INTERNET WORKING HOW I FIX
try this trouble shooting guide and let me know what happens from there. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
Jul 17, 2010 | Nintendo Wii Console
EROR CODE 52031 ON NINTENDO WII
Hi,If you’re using WEP or WPA for your router’s security, log into your router by typing its IP address in your internet browser and make sure your WEP or WPA key entered in the Wii matches the key in the wireless router. The WEP Key can only use characters 0-9 and A-F. If your router allows more than one WEP Key to be entered, make sure the key in slot #1 is the active key. The Wii can only use the key in slot 1.If you entered the correct key, then check to see if MAC filtering is enabled in the “access control, access list, or network filter” section of the wireless router. If MAC filtering is enabled, you will need to enter the Wii’s MAC address into the “allowed” list for MAC addresses.
If none of these were the problem and your connection used to work, try power cycling both the router and modem by unplugging both from the wall. Wait a couple of minutes before plugging the modem back in. Wait another couple of minutes for the modem to initialize, then plug the router back in and wait until the router initializes.
Ensure that your wireless router has the latest firmware installed. You will need to go the router manufacturer’s website to download the firmware.
If Wii Error Code 52031 is still a problem, try changing the broadcast channel of the wireless router to 1 or 11. This can help increase download speed.
You an also try manually entering the Wii’s internet settings. You will need to first get the network configurations from your PC.
On your PC, click “Start” and then “Run.”
Type “CMD” into the field that appears to open a new window.
Type “IPCONFIG/ALL” and press “Enter” to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Good luck
Jun 10, 2010 | Video Game Consoles & Games
When trying to connect my wii to the internet, one of two codes always pop up. either 51330 or 51332. How can I fix this??
this is a error for internet security most likely in the wep key. Follow the steps below and if you still need assistance let me know and i will help you from there. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
Apr 16, 2010 | Nintendo Wii Console
Trying to get on internet but its asking for a wep key or a wpa key I just completed hook up to netgear router have desk top and a wirerles lap top laptop is asking for info
The WEP and WPA key is configured in the router's wireless settings.
WPA is a stronger encryption than the older WEP encryption, I suggest you use WPA or better still WPA2.
To secure your wireless network, configure the wireless router and the wireless card in the computer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 25, 2010 | Computers & Internet
I have a wpn824-2 and I am trying to set up a connection from my lap top. It is asking me for a network key or wep key. Where do I find it?
You can get the WEP or Network Security Key from the Router.
Login to the Router as follows (make sure that it is connected to the Computer using LAN-Wired connection):
1. Start the Web Browser like Internet Explorer or Firefor or Safari.
2. Type 192.168.1.1 as the URL.
3. Type "admin" as user name and as "password" as password.
4. Go to the "Wireless Settings" option.
5. Set the Wireless Network Password (either WEP or WPA key) will be listed next to Security Encryption.
You may also use any third party utility to get the Wireless Security key save in the Computer (in which wireless connection is working and key is saved).
Good Luck!!!!!!!!!!!!!!!
Nov 19, 2009 | NetGear RangeMax WPN824 Wireless Router...
Secure wireless internet
The D-Link is configured using a Web browser. After you have connected your computer to the D-Link router, follow these steps: 1. Launch your Web browser. Enter "http://192.168.0.1" into the address bar and press the "Enter" or "Return" key.
2. A logon pop-up screen will appear. Type "admin" for the username and leave the password field blank.
3. Click "OK". A D-Link configuration screen will appear. All changes to the D-Link configuration are made here.
Enabling WEP* (Wired Equivalent Privacy) will require anyone wishing to access the Internet through your wireless network to enter a password. After the correct password is entered, a connection is established, and all data sent from the D-Link to the computer and back is encrypted. From the D-Link configuration screen:
1. Click the "Home" tab.
2. Click the "Wireless" button.
3. Click the "Open System" button next to "Authentication".
4. Set the "WEP Encryption" to "128 bit".
5. Set the "Key Type" to "ASCII".
6. Type a 13 digit password into "Key 1".
7. Click "Apply".
8. When you connect to your wireless network from a computer, you will need to enter the 13 digit password.
*Note: If your computer's operating system supports it, enabling WPA-PSK is more secure than WEP. The steps above can be modified to set up WPA-PSK.
May 10, 2008 | D-Link AirPlus DI-524 Wireless Router
Belkin (F5D7230-4) Router (587009) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
