Can I buy an adapter that will read both drives at the same time as I believe data is split between both drives
  • 518 Answers
Normaly the drives are set up so one is master,andother is the slave all data is sent to the master,,data can be transfered to slave but done manualy not automaticly,
Posted on Jul 07, 2010
Dear Sir We rely on an external contractor to backup our data. We need to retrieve the data and got this reply: " [...] I have just been down to the computer room and checked. Your data backup is...
these tape cartridges are very slow to read & write. if u r reading a set of data & need to go back for certain data u have to rewind & wait & watch until that data area arrives. it takes a lot of time. in order to save time u need optical disk drives & dvds to backup your data. u can also ask them to convert your tape cartridge data into optical disks.
Sep 13, 2011 | Smead Manufacturing Company Sony AIT5 Tape...
When i turn my compaq Evo N600c i get this message "1720 SMART hard drive detected imminent failure (failing attr : 05 ) " please help
If you want to save your data, start backing it up now!!!
That hard disk has detected bad sectors or other issues that is causing read, write or read/write failures.
The best thing to do if it's out of warranty is get a new hard disk and clone this drive to that one using a program like Acronis True Image.
Where you get the new hard disk will probably sell external enclosures or a USB adapter cable that you can use to have both hard disks hooked up at the same time to perform the drive cloning, or most computer shops if you are buying the drive from them will provide this service either free or for a modest fee.
Use the drive (meaning the laptop) as little as possible until you get a new drive into it.
Mar 25, 2011 | Computers & Internet
PNY micro small piece inserted in mobile phone and adapter to the computer, but not copy mobile phone pictures to the computer.
for reliability buy a dedicated micro sd reader as not all the adapters work.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | PNY 2GB microSD Memory Card
How do I use the Micro SD port?
hi.
sd port is use for read yr sd card.. put yr sd card in sd port then yr can read it from clisk my computer icon and ten yr card will be locaten in g/h/f or try click 1 by 1 memory stick drive
regards
Feb 21, 2011 | eMachines Desktop / AMD Athlon Processor /...
Plugged in drive to computer and it completelly locked. unplugged and tried again and got I/O error. Now has various responses. Sometimes wont read at all, sometimes see the directory structure but no...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 13, 2010 | Western Digital My Passport Essential SE...
Hi My hard drive crashed can it is old can it be
Most likely scenario is the drive is dead, but also the BIOS on your computer is old itself, I believe there are a few BIOS upgrades available for that model, might want to check with Dell support site. If you have access to another computer, there is a way to check your drive. Go to a computer retail store or on Ebay, but a EIDE/SATA to USB adapter. This will allow you to take a hard drive out of the case and attach this adpter to it and plug the usb side into another computer, laptop, doesn't matter...that computer will read the drive as an external hard drive....if the drive is indeed still viable. If it is, this would be a good time to save your files to the other computer for safe keeping until you can get your other system back on its feet.
Oct 10, 2009 | Dell Dimension 4600 PC Desktop
Woleryi ~ emachine per your suggestion....
Here is what you need. Go to a computer retail shop or get it online. You need an IDE / sata USB adapter cable. Here is what it does....you take the hard drive out of the damaged computer and attach the adapter to it, the other end is a USB plug that attaches to tyour good computer. Your good computer will read the drive on the usb cable and treat it as an external hard drive that you can copy and paste till your heart's content. The adapter dell for around 20-35 bucks. It is the safest way to transfer all your documents, favorites, nusic, Etc from the old system.
Sep 11, 2009 | E-Machines eMachines Desktop PC
Lost ac/dc adapter for a 320 GB Simpletech External Hard Drive
I have the 320GB Simpletech External Hard Drive.
The AC adapter Model number is SAWA-05-153
The output is +12V --- 1.5A
Nov 16, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Computers & Internet Logo
David Payne
David Payne
