Question about Teac Audio Players & Recorders
Reels will not turn in either direction on play.
I have a TEAC ( Model # A-4010S) reel to reel I bought in 1968
while in the Navy. Worked fine all these years but stopped playing this weekend. Works fast forward either way but won't turn in either direction.
I took off the back and cleaned all the dust out and sprayed the components with contact cleaner. If I don't thread the tape from reel to reel and over ride the shut off switch reels turn very fast and don't change direction in reverse. Does not appear too change speeds either.Help!!!
  • 476 Answers
Hi, the contact cleaner could get to the drive pulley or drive belts, what you need to do is to lube the forward/reverse solenoid actuator arm and pivot links and another area that gets hard to move is where the pinch roller mounts and slides into the tape, the lubrication in that area gets old and hard, so applying a bit of 3in1 or light lube will due the trick, overall you are looking at a clean and lube job and not an electrical or electronic repair, also inspect either the idler wheel or the drive belts for possible wear, after more than 20 years of exsistance it is possible they need to be replaced. Try the evg products website for possible belts and or idler replacements, don't know if they still have the belts for r/r recorders. Good luck!
Posted on Jul 12, 2010
Teac X-300R doesn't play with tape
Here's a great forum that may help. Sounds like an internal belt problem.
http://www.tapeheads.net/showthread.php?p=360709
Dec 03, 2013 | Audio Players & Recorders
Teac a-3440 will not play
Hi Gary,
This makes me think the Capstan Shaft is not turning either due to a broken or stretched belt or that the capstan motor itself has stopped working. This may be a job for a Technician. You first determine if the Capstan is turning or not- this is the metal post that contacts the Pinch Roller that rotates and is the way the deck gets it's speed regulation. If it is not turning look inside the deck from the side to see if the flywheel is turning and that the belt is on that flywheel. Lastly make sure the capstan motor is turning.
Beyond that a Tech may have to take over from there. I am in the Chicago area and can repair it if you are close. Many people send me units from all over the USA anyway.
My name is Sam. I operate Skywave Tape Deck Repair
skywavebe@sbcglobal.net if you need my help.
Aug 17, 2012 | Teac Audio Players & Recorders
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
Just aquired a teac a3440. The unit powers up and reels spin and in fast forward or reverse they work fine. After loading a tape there doesnt seem to be enough power to spin the reels. Please help David
moz-screenshot-1.pngI can give you a figure. Here can be seen the tape transport parts location. This probably will help you fix the problem:
If you need to get a global service manual it can be downloaded via this link, but you need to register your free account before:
http://www.hifiengine.com/manuals/teac/a-3440.shtml
gylacz
May 03, 2011 | Teac Audio Players & Recorders
Need operator manual for open reel teac ar-40s
You may find it easier to look for a manual for a Teac reel deck A-4010S. This will serve you also.
Dec 02, 2009 | Audio Players & Recorders
Reel to reel plays audio backwards
HAVE YOU TRIED TURNING THE REELS OVER? ON SOME PANASONIC UNITS THE REELS CAN BE PLAYED IN EITHER DIRECTION BUT THE SOUND IS REVERSED IF THE REELS ARE UP SIDE DOWN. TRY TURNING THE REELS OVER AND IT SHOULD STRAIGHTEN OUT YOUR AUDIO PROBLEM AS WELL AS BOOST THE VOLUME
JAMESFWALKERJR2006@YAHOO.COM
Aug 29, 2009 | Quantegy 456 Reel-To-Reel Recording Tape...
When play is punched in either direction it want move,not even in
yes, one nice overhaul will fix..(this can be done by you if you are daring...when u open take apart you will find a metal strip like band..I had used a bandaid for brakes the gauze side) you need new brakes (just like a car it is run down) on the reels in order for it slow & stop when it suppose to...or you can search and find a good old fashion repairman..(sorry I dont know of none)...for dragging, before playing all open reels fast fwd to one end then rewind it back to the beginning now hold the blank reel with that little bit catch tape try to tighten full side tape by going slightly going the other way not trying to stretch nor pop the tape.....now press play
Aug 07, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Jul 18, 2008 | Audio Players & Recorders
126 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
