Question about Car Audio & Video
I just bought new kenwood speakers for my 1999 subaru forester and because the stock ones were shot and i was wondering if i should replace the stock clarion deck to
SOURCE: Wiring for a kenwood kdc 1020 cd player
if you have the wire connector it's easy.....give the negative conection to the body of the player..find the wire from the battery with has the power supply even when the switch is off..and connect it to the yellow wire.that is for the memory...find the wire which has the power when the switch is on ,and connect it to the red wire from the player....what i mean by switch is the ignition switch... u can easily find the speaker connections...most speaker wires comes as blue,ash,green,white...there are two wires from each colour......
Posted on Dec 09, 2008
doin12volt
  • 233 Answers
SOURCE: kenwood deck reads protect and won't function
you have one of your speaker wires shorted out to the body of the car somewhere, or the speakers that you installed are bad. That is the only two reasons it will go into protect. Correct the problem, then reset the deck - it should work fine.
Kenwood builds this feature in to protect the outputs - so they dont burn up in the case of shorted speakers or wiring.
Posted on Jan 17, 2009
  • 80 Answers
SOURCE: How do I replace a rear window motor on a 1999
first the door panel must be removed, once inside at the bottom of the door glass you will see it is attached to the regulator bar with to bolts, remove them separating the door glass from the regulator. (most of the time you must move the door glass up and down for the bolts to line up with an access hole so they can easily be removed...I assume your motor is shot and the bolts may be difficult to remove). the regulator has to be removed as the motor is attached to it. I'm not familiar with this one, but there is usually 3 or 4 bolts around the motor area and 2 bolts on the idler arm track, once removed the regulator should be free to wiggle out. remove the motor from the regulator.
Hope this helps.
Posted on Mar 12, 2009
budice7h20
  • 93 Answers
SOURCE: Will 2 KENWOOD KFC-6982iE fit in 1999 mazda protege
If they fit then put them in. The only thing is, if your not using a amp they may not sound good.
Posted on Jul 02, 2009
abauto
  • 353 Answers
SOURCE: where is the knock sensor located on a 2001 subaru
When facing the engine it is in the rear right hand side.
The knock sensor is a piezo electric crystal, when they go bad the must be replaced.
Looks similar to these
Posted on Sep 22, 2009
I bought a Subaru Forester 2009 that has a Kenwood HDV-790 navigation system It came with a Japanese user manual .Can you assist where I can get a manual of English vrsion
I would go to Kenwoods website and look for a link to their support center and see if they have online manuals or at least ordering capabilities. Most of the big electronics companies have this option, I did it for my JVC stereo. I lost my manual over time, had to replace the battery in my car and had to reset most of my settings on my stereo and I was able to get one from JVC. Just make sure you write down the number on the front of your unit on some paper so you can research it by model on there site. I hope this info helps!
Apr 24, 2015 | 2009 Subaru Forester
1999 Subaru Forester Where is fuse for electric
you may find the fuse diagram on the inside of the fuse box cover, try looking under the dash there might be another fuse box there.......hope this helps....cheers
Sep 13, 2010 | 1999 Subaru Forester
Owner's manual
call the dealership and ask them or look it up on ebay
Jun 19, 2010 | 1999 Subaru Forester
How to replace a 1999 subaru forester non-turbo
please my solutions i am All Data computer Erase.
key.
Apr 16, 2010 | 1999 Subaru Forester
My clock light on my 2004 Subaru Forester won't light anymore. The dome light works so I know its not a fuse.
Is this for a 1999 Forester or for a 2004 forester, the title lists both years. If it is a 1999 model then the problem most likely resides within the clock itself. Unfortunately, many clocks of this vintage go bad over time. I offer a reasonable repair service and many clock removal instruction sheets at www.autoclockrepair.com
I'd be happy to assist.
Feb 25, 2010 | 1999 Subaru Forester
99 Subaru forester s/tb type A
You want to change from a standard transmission to an automatic transmission? You need a new transmission, clutch, gearshift, shift linkage just to start. You will be money ahead selling the car you have and buying one with an automatic.
Dec 29, 2008 | 1999 Subaru Forester
Nov 21, 2008 | Kenwood KDC-MP235 CD Player
Car Audio & Video Logo
164 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
