Question about Sony DCR-PC55E Mini DV Digital Camcorder
LINES ARE APERING ON THE SCREEN ON PLAY BACK - Sony DCR-PC55E Mini DV Digital Camcorder
My model# sbm7500w sunbeam microwave is apering to be working but wont get hot
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 05, 2011 | Sunbeam SBM7500W Microwave Oven
Gray horizontal lines in video playback
dear ,
i Jasdeep working in superb broadcast as an lengineer .and for this problem i can suggest u the following things :
1. Play back the cleaning tape for 10 sec. only then use it.
actually this problem occurs when the head get clogged (i.e, dirty ) it REC. only single band and shows the same in play back too.
Jun 27, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Lines on tape when played back or maybe they are only on viewfind
most likely head problem, try to clean with special tape.If still lines appeared on screen ,head must be replaced.
Dec 13, 2008 | Panasonic AG-DVX100B DV Digital Camcorder
My Cannon ZR200 was working good but now when I play back my dv tape there are 5 gray lines on my camera screen and the tv if I play back on the tv, I can play that same tape in my brothers camera with no...
It sounds like your saying the gray lines are appearing on your camera and on the tv when you play from the camera but not on your brothers camera. It sounds like your heads are dirty. Get a head cleaner and you should be good to go. Please take a moment to rate my solution fixya.
Thanks and enjoy,
Lee
Dec 07, 2008 | Cameras
Lines on my JVC mini dv recorder
Please use Mini DV Video head cleaning cassette as it seems video head is dirty / clogged in camera.
Oct 24, 2008 | JVC GR-D295U Mini DV Digital Camcorder
JVC Camcorder
Put an used casette inside; hit PLAY and then FFWD until you start seeing images. Eventually you will start seeing some with lines and then the black lines will get smaller and smaller until they turn into grainy lines. Stop and PLAY again and they will faint. RWD and PLAY back as you wish and it should be find. I think this is because of tiny dirt particles that your cassette will dust off for you.
Aug 26, 2008 | JVC GR-D270US Mini DV Digital Camcorder
OMG HELP!!PLEASEEEEEEEE WIERD LINE SHOWING UP
plesw see your LCD settings or remove your screen wipe if and then fit it and restart
Oct 21, 2007 | Nintendo Wii Console
Pink strips through screen and tv when playing back tapes
clean the heads - the '5 stripes' are the symptom of dirty heads.
May 16, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
White lines down the screen
Hey buddy, you have switched ON the TEST SIGNAL switch at the back of the VCR. Pish it to TEST SIGNAL OFF.
Mar 29, 2007 | Sharp VC-A373U VHS VCR
Sony DCR-PC55E Mini DV Digital Camcorder Logo
22 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
