Question about Beverage-Air MT27 Beverage Cooler Commercial
The refrigerator constantly shuts on and off and does not stay on what could be the problem
  • Beverage-Air Master
  • 1,711 Answers
Posted on Sep 15, 2010
Refrigerator runs constantly
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE.
May 17, 2014 | Samsung Refrigerators
Freeze temp is not holding zero
When the compressor shuts off the freezer temps will slowly go up until the compressor recycles. The temp will not stay at a constant zero but fluctuate back and forth in accordance with compressor function. My temps vary from -2 degrees to about +4 degrees when the compressor kicks on again.
Nov 27, 2013 | GE Refrigerators
Hotpoint Refrigerator constantly runs and doesn't shut off normally.
Sounds like the thermostat is not working that is what tells the compressor it is cold enough shut off.
May 17, 2012 | Hotpoint Refrigerators
Freezer fan stays on constantly. temps ok in both sides. will this cost much more electricity and should i really worry about it.
If the freezer fan is running constantly, and things aren't too cold in either section, it means the frig thinks its not cold enough to shut off, so it runs trying to get to the proper temp. you have control set at. Check for any frost buildup on freezers back panel inside freezer. If there is you have a defrost problem.
Oct 01, 2011 | Hotpoint HSS25GFP Side by Side...
The freezer constantly drips water even with the ice maker turn off, the fan constantly runs but when the door is open the fan shuts off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Microwave Ovens
Our amana refrigerator is a BX21TL. Serial # 9809197207. It is approx. 8 years old. The freezer wont stay cold enough? I would guess it approx. 35-36 degree's... Help...
First is the refrigerator running constantly, if it is then it is probably low on freon also check that all the door seals are good as this can keep it from freezing properly. If it is not running constantly but running and shutting of and restarting as it should normally then you may have a bad cold (temperature) control shutting it off before it gets cold enough. Also check that there is clearance for the air to flow around the outside of the refrigerator as the evaporator coil transfers the heat from the refrigerator. This evaporator coil is usually mounted on the back of the refrigerator and needs to have unrestricted air flow. Be careful of electrical shock while working on it. Always unplug first you only get electrocuted once no second try.
Oct 08, 2009 | Amana Refrigerators
Icemaker arm doesn't stay in the up position
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The switch on the shut off arm is defective!
Call service and they will help you replace it!
Please remember to leave a rating before you go!
Thank you
Sep 23, 2008 | Whirlpool GD2SHGX Refrigerator
Beverage-Air MT27 Beverage Cooler Commercial Logo
247 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
