Question about Hoover HF7 160E Front Load Washer
Hoover SE 160E stops mid-cycle start and crease lights flash
I have a Hoover SE 160E which stops mid cycle with the start and crease guard lights flashing. The washing machine seems to stop prior to the spin cycle and the drum has been emptied of water. Any suggestions to the fault? The appliance is over 5 years old.
5 Suggested Answers
  • 1462 Answers
SOURCE: Machine stuck mid cycle
filter blocked or brawire or similiar in drain pump take off cover at bottom rear. take of hose going to bottom of tub. filter is in that hose you will have water everywhere. one way round that is to lay machine on side - left side down viewed from rear
Posted on Mar 20, 2007
SOURCE: Instructions for Hoover Washer Time 160E
i have a hoover soft wave maxi 1600 7.5kg AAA it spins and empty's and sometimes it don't what could be the fault
Posted on Dec 02, 2008
  • 105 Answers
SOURCE: what Temperature is crease guard. also fast wash
usually crease guard is a combination of hot and cold (warm depending on water temp and water pressures)
Hoover fast wash is generally a shorted time cycle of the normal washes
Posted on Nov 20, 2009
barkencoa
  • 3463 Answers
SOURCE: Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Posted on Jan 16, 2010
Pre-Wash and Crease Care lights flashing?
WHILE IT IS LOADING WATER, TRY TO ADVANCE THE WASH PROGRAM; INSTEAD OF LARGE CAPACITY GO TO MEDIUM.
Jun 20, 2015 | Washing Machines
How can I stop the lights from flashing mid cycle and make the machine continue its cycle to the end and drain?
first you need to take off the drain hose that allows the water to pump out and check to see if it is blocked at the part that it connects to from the machine , you could try to blow back the water but if its blocked i doubt it , after you remove the hosing inspect the inside of where it fitted onto , with the cord unplugged from the wall you might be able to use a bit of wire with a tiny hook bent onto it and pull out any blockages . also make sure the water pump is engaging when it goes into the pump cycle .
Aug 07, 2017 | Washing Machines
I have a ATF7000FS1 washer that has been pausing the wash cycle on it's own. I will have to press the start/pause button during the cycle to restart. This happens several times during a wash cycle. How...
some machine will stop before spin its called crease guard if you are useing a low temp cycle its there to give you the option to stop your cloths wrinkling try another cycle
Nov 08, 2011 | Frigidaire Affinity ATF7000E Front Load...
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Jan 16, 2010 | Hoover Washing Machines
What Temperature is crease guard. also fast wash on hoover 1300
Nov 20, 2009 | GE S8000E
Not completing cycle
if your waste pipe is attached to the sinks waste you might find the wastepipe connection blanked off, simply unscrew and remove blank. Or your water supply maybe off.
Feb 20, 2008 | Hoover Nextra HNWF 3135 Front Load...
Hoover HF7 160E Front Load Washer Logo
139 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
