Question about Toshiba E-Studio 3511 Color Copier
How do replace the transfer kit - Toshiba E-Studio 3511 Color Copier
    Problem Solver:
  • 11 Answers
Its quite a tricky one .. you defo need the manual if you have not done it before ...
Posted on Jul 13, 2010
To printer 4025
you need to go where it says Service then input that code and scroll to reset the belt. ( this only needs to be reset in Service mode when changing before the counter says to.)
Dec 05, 2016 | HP LaserJet Office Equipment & Supplies
How do you install a transfer kit to 4700 dtn printer?
Replacing the ETB (transfer Kit)
Replace the ETB when a REPLACE TRANSFER KIT message displays on the control panel.
1. Turn the printer off.
2. Open the top and front cover.
3. Lower the ETB by pulling the green handle at the top of the unit downward.
4. Press the small blue latches located on either side of the bottom of the ETB and lift the unit out
of the printer.
5. Install the new ETB.
6. Close the front and top covers.
Jan 13, 2011 | HP LaserJet 4700 Printer
My 4700dn is giving me the replace transfer kit message. I have swapped out known good transfer kits and the printer prints fine but I still get the replace transfer kit message. What can I try next?
The message only clears when you install a new transfer unit, one that hasn't been used before. If you want to clear the message, you'll have to install a brand new transfer belt.
If you know the service PIN for the 4700, you can probably go into the service menu and clear the message, but otherwise a new transfer unit is the only way to go.
Aug 11, 2010 | HP LaserJet 4700 Printer
My 4700 hp printer is double printing and giving a replace transfer kit notice
This means you'll have to replace the transfer kit because it is "end of live". This also causes the printing problems. The transfer unit is the big black unit you'll find when you open the front cover.
Jul 29, 2010 | HP LaserJet 4700 Printer
I have a hp 2600n and when printing ink spots are over the document
First replace the inset and try printing a test page,if problem persist,replace the DC board and if problem doesn't pls replace the transfer kit/electrostatic transfer kit.let me know as soon as you the following.
Apr 20, 2010 | HP Color LaserJet 2600n Printer
Asking to replace transfer kit - old printer is this necessary? Can it be over ridden?
You can not over ride it. You can keep on printer till the printout gets bad. Then you will have to replace the transfer kit.
Gerrit Jan
Nov 11, 2009 | HP Color LaserJet 3500 Printer
Transfer kit
The transfer kit is unrelated to the toner. On most printers it gives you the message that it needs replaced after X number of prints. Depending on page coverage and the quality of the paper you are using there may still be some life in it and you can clear the message and print until the image quality is affected then change it.
May 29, 2008 | HP LaserJet 4600dn Color Printer
Installing a Transfer Kit
i got this info from www.partshere.com site - they have most service notes for hp printer and sell most hp parts, including maintenance kits. I hope info. bellow is helpfu.
Replacing the transfer unit
Replace the transfer unit when the printer control panel displays REPLACE TRANSFER
KIT
. The image transfer kit contains a replacement transfer unit for this printer.
WARNING! Remove any jewelry or any other metal items from your body to avoid electric shock.
1. Lift the front door handle and pull down the front door.
2. Grasp the right blue handle. Press and hold down the blue button. Slightly lift the right
side of the transfer unit.
3. Grasp the left blue handle and lift to remove the transfer unit from the printer.
4. Using handles, remove the new transfer unit from the bag. Use the blue handles on both
sides to hold the transfer unit.
5. Place the new transfer unit on a flat surface. Remove the orange shipping locks.
6. Guide the left side of the transfer unit into the front door of the printer. Insert the two
pegs on the left side into the holes, and then lower the right side into the door.
7. Make sure that the blue button on the right blue handle has released (popped up). If the
button has not released, grasp the right blue handle and pull the transfer unit toward you.
8. Firmly close the front door.
9. After the front door is closed, after a short time, the printer control panel displays the
message NEW TRANSFER KIT.
10. If the message NEW TRANSFER KIT does not appear, you must reset the transfer unit
count. To reset the transfer unit count, go to step 11.
11. On the printer control panel, press to highlight YES, and then press to select it. The
transfer unit count is reset, the printer recalibrates, and then the printer is ready to use.
NOTE If the old transfer unit was not at end-of-life when it was replaced (for example, if it was
damaged), the transfer unit count must be reset using the printer control panel.
Replacing the transfer unit when it is not at end-of-life
If you replace the transfer unit when it is not at the end-of-life, for instance if it is defective,
you will need to reset the transfer unit count and then calibrate the printer, through the
control panel.
To reset the transfer unit count, do the following:
1. Press MENU to enter the MENUS.
2. Press to highlight Configure Device.
3. Press to select Configure Device.
4. Press to highlight RESETS.
5. Press to select RESETS.
6. Press to highlight RESET SUPPLIES.
7. Press to select RESET SUPPLIES.
8. Press to highlight NEW TRANSFER KIT.
9. Press to select NEW TRANSFER KIT.
10. Press to highlight YES.
11. Press to select YES.
To calibrate the printer, do the following:
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
The transfer unit count is reset and the printer is ready to use.
see pictures on link:
http://www.partshere.com/Models/Q5990A/CLJ_3550%203500%203700Installation_n_config.PDF
Apr 18, 2008 | HP Color LaserJet 3500 Printer
"replace transfer kit" for Konica KL-3015
Hi Hexus, http://www.kmbs.konicaminolta.us/eprise/main/KMBS/Support_Center/Manuals/Pages/Attachments/3015gs.pdf Download that manual the directions with diagrams for replacing the transfer kit are on page 40 (in the page numbers on the docs themselves, the Acroreader page number is 51) Hope that helps, El Duderino
Nov 21, 2006 | Konica KL-3015 Laser Printer
Toshiba E-Studio 3511 Color Copier Logo
51 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
