Question about Frigidaire Refrigerators
My fridge trips the breaker when you try to turn it on
  • Frigidaire Master
  • 3,289 Answers
I have a couple of things for you to check or rule out. Today, a refrigerator is required by electrical code to be connected to a dedicated, 15 amp outlet because the newer fridges are more efficient and use less than 12 amps. Not long ago, a dedicated 20 amp outlet was required because the older fridges were rated to use 12 amps or more (but less than 16 amps) and needed the larger size circuit. A 20 amp circuit breaker or fuse should not open for any standard residential fridge under normal operating conditions. A 15 amp circuit breaker or fuse _MAY_ open if an older fridge (needs 12 amps of more) is connected. Make sure that if a circuit is opening at the fuse or breaker, it is not because there are several appliances or devices in use and on the same circuit as the fridge.
The same holds true for "ground fault" and "arc fault" type circuits. If an older fridge is connected to such a circuit - nuisance tripping may result. Most newer fridges however shouldn't cause a problem on these circuits. Ground fault circuits have a "test" button on the circuit breaker or, "test" and "reset" buttons on an outlet providing this protection. Arc fault circuit protection is available only in circuit breakers (as of this time - but may become available as outlets some time in the future).
If you need to to try to isolate the problem on a 20 amp circuit, disconnect all other appliances on the other 20 amp circuits in the kitchen and dining room, then see if the fridge stays running. Alternatively, you could use a heavy duty extension cord to connect the fridge to a known isolated 20 amp circuit to see if the fridge runs. This is meant only to troubleshoot - the fridge should not be left connected via extension cord for normal operation.
If you still have tripping, you might need to have the fridge professionally serviced, as a ground fault could be a dangerous condition left unchecked.
Please rate this replay id found to be helpful - good luck!
Posted on Jul 07, 2010
Oceti
  • 51 Answers
SOURCE: fridge/freezer trips my circuit breaker
This sounds like a grounded wire in your defrost system. Start by finding the defrost timer and checking the wires. One may have been pulled loose or pinched while it was being moved.
Posted on Dec 13, 2007
gaeb7
  • 25 Answers
SOURCE: Fridge keeps tripping the circuit breaker
Your fridge should draw no more than 5amp. Presuming your breaker is at least 15amp there's a problem. Move to a different circuit first. If the condition persists check the start relay on the compressor. I have a suspicion the circuit may have another item you are not aware of.
Posted on Mar 01, 2009
get an inexpensive clamp amp meter (Harbor Freight has them). Turn off power to the plug. Remove plug from wall but do not disconnet wires. turn fridge OFF. plug the unit in the recept. turn on the power. set the meter for the higest reading (amps) & clamp it around the black wire. turn the fridge ON & observe start up current & the "run" current. If the fridge is within limits on the data plate the problem is in the wiring circuit, maybe a loose connection either @ the plug or the breaker. if there are several plugs in the circuit, the problem could be in one of them. In addition, if there is a gfi plug in this circuit, it could be faulty also.
Posted on Mar 02, 2009
Sea Breeze
  • 4655 Answers
Unless there is a dedicated circuit of 20 amps to the refrigerator this will continue to happen When your refrigerator goes into defrost and other things like lights fans air conditioners are on the same circuit it will have no choice to not trip the breaker. Try this turn the breaker off and how may thing in your house stop working? You need a 20 AMP circuit or this will possibly damage the compressor or weaken the breaker because it has tripped so many time. Thanks, Please rate my solution, I have done this work for 30 years. Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Posted on Aug 29, 2009
  • 2468 Answers
SOURCE: Maytag fridge trips circuit breaker
replace the ptc overload relay on the compressor,it merely unplugs,it supplies start and run power to the compressor and if its bad it will allow the compressor to operate on the start windings too,and draw a lot of current
Posted on Apr 06, 2010
Fridge blow fuse. What can be wrong?
There could be a lot of reason but most common reason for unit tripping breaker is bad compressor .
Disconnect compressor and turn breaker back on and if breaker didn't tripped then it's definitely the compressor. If breaker still tripped then there are other issues .Check all electrical wiring because something is grounded
Jun 01, 2017 | Refrigerators
When the fridge is turned on it trips the electrical power
You might have a short in your outlet to cause a surge to your breaker. You also might have too small of a breaker to run all of your appliances on it. Should be atleast 20A breaker in the kitchen.
Apr 01, 2012 | Refrigerators
The fridge shut off and tripped the breaker, tried to reset breaker and it tripped again. I unplugged fridge, breaker was able to reset, voltage good at outlet, ohmed out fridge plug, appears to have a...
Could be anything, bad cord or plug, possible bad appliance bulb causing short (had that happen on another appliance) or the main problem, bad compressor.
Sep 05, 2010 | Refrigerators
Hi, my fridge freezer keeps making the electric trip out. help!!!
Try this:
Turn your thermostat as warm as it will go, you are trying to isolate the compressor and keep it from turning on. If your fridge has an "off" position, then turn it off. Reset breaker, plug refrigerator back into the outlet. If the fridge trips while "off", then you are likely looking at a damaged cord / wiring.
If the breaker doesn't trip, unplug the fridge, and move the thermostat to the warmest position possible. Plug fridge back in, If the breaker holds, then you are on right track. Slowly move the thermostat to a cooler setting. You want to just reach the point where the compressor tries to start. If breaker holds here, then you are in good shape so far. It indicates a problem with the defrost heater (if equipped), or the ice maker (if equipped). If the breaker trips as soon as the compressor tries to start, your compressor may be damaged (bad and expensive).
Aug 17, 2010 | Refrigerators
Apr 06, 2010 | Refrigerators
About 1:00 am this morning our fridge tripped the circuit breaker, it ha never done this before. I reset the breaker and it tripped 5 mins later. I left it unplugged for the rest of the night. I plugged it...
It sounds to me, either you have a bad circuit breaker (the breaker itself); or you have a bad motor or compressor in the fridge. If possible try plugging the fridge into a different outlet. (If you use an extension cord to do this, make sure it is a thick gauge, in order to not cause an increase in amps through the smaller cord.) This should tell you rather quickly if the problem is with the breaker or the fridge. If it does turn out to be the fridge, you will probably find it is cheaper to replace a fan rather than the fridge, but the compressor (including installation) would probably cost more than a new fridge. (depending on how "fancy" it is)
Hope this helps
Sep 29, 2009 | Refrigerators
Jul 10, 2009 | Whirlpool ES5FHAXS Side by Side...
RM4236 tripping site electrics
Paul;
Are you tripping the shore power pedestal? If so did you unplug the fridge and try it. The park pedestal breaker should be at least 30 amp and I can not believe the fridge would trip the site breaker before it tripped the breaker in your caravan. Are you sure it is the fridge? Your fridge is an old eletrolux dometic and I can not find the manual in my files. You may call Dometic and get a manual but That will not help you much. I will be more than glad to resolve your problem but I need more info.
The Dometic# is 800 366 3842. Prompt to tech dept.
Repost to us
Thank You for using Fixya
Jerry
Mar 26, 2009 | Electrolux Refrigerators
Mar 01, 2009 | Refrigerators
Mar 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
716 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
