Question about Sport & Outdoor - Others
I have just (today) came in possession of a Precor 9.4 e.i..s. the person who owned it prior said other than a bad on off switch this unit had no problems. I realize people lie (believe me) but the unit appears to be in remarkable condition (one owner) everything is is pristine clean and in as new condition. belt is like new clean dust and dirt free. the treadmill runs fine (by itself) as soon as you place a load on it (i.e. Me) after a short time the circuit blows. conversely (for some reason) I tried running a heavy duty (grounded) extension cord into the bathroom plugging into the gfi plug. i let it run then got on it myself. There after I gradually increased the speed (having no problems) it was not until after 8 mins of on again off again load to the unit the circuit once again blew.
If it's blowing the circuit, the most probable cause is a worn belt. Too much friction is building up between the belt and the deck, causing an overload from the control board to motor. The top surface of the belt probably looks great, but if you feel underneath the belt toward the center, if it feels like rubber then the belt needs to be replaced. The sides of the belt on the underside (where you really don't walk at all, will pretty much have a cloth-rough surface to it. That's how it should be in the center as well.
-CT Treadmill Repair
Posted on Jan 02, 2011
I keep getting a speed error message when I start the belt
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error LS, Speed Sensor Signal Missing Probable Cause 1. Intermittent or open connection of the speed sensor (reed switch) wiring.
2. Reed switch is defective or has intermittent connection.
3. Drive motor brushes are bad.
4. Lower PCA is bad.
Corrective Action
  1. Inspect the speed sensor (reed switch) wiring for damage or poor connection to the lower PCA. Replace damaged wiring or reset connection as necessary.
  2. Using an ohm meter, test the reed switch while rotating the drive pulley. The reed switch will close when the magnet passes in front of it.
  3. Inspect the drive motor brushes and replace if necessary.
  4. Test unit with a known good lower PCA. Replace lower PCA if necessary.
Precor Error Code LS
Dec 08, 2014 | Precor Exercise & Fitness
Stuck key on machine wont start
Precor Error 05, Key Depressed at Power Up
Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
This link will take you to the parts available for these models. Because most machines are serial number specific, you will need to narrow your search based on your particular model and serial number.
Precor Repair Parts for 9 35 9 35i Treadmills Consumer SPORTSMITH net
Jul 22, 2014 | Precor 9.35 Premium Series Treadmill
Stuck key
Corrective Action
Precor Repair Parts for 9 33 9 33i Treadmills Consumer SPORTSMITH net
Jul 15, 2014 | Precor 9.33 Treadmill
Precor gfx 9.33i displays "stuck key"
Corrective Action
Apr 20, 2014 | Precor Deck, Treadmill, OEM
Error code LS
Corrective Action
Mar 26, 2014 | Precor Exercise & Fitness
Precor L5 error
Corrective Action
Dec 19, 2013 | Precor C954i Commercial Treadmill
Precor error codes 53
Precor Error 53, Can't Read Target, Can't Find Home Switch Probable Cause 1. Blown F2 fuse.
2. Home switch wiring is damaged or has intermittent connection.
3. Gear (elevation/incline) motor wiring is damaged or has intermittent connection.
4. Home switch is bad.
5. Gear (elevation/incline) motor is bad.
6. Gear (elevation/incline) motor target is damaged.
7. Lower PCA is bad.
Corrective Action
  1. Disconnect power from the unit. Remove the F2 fuse from the lower PCA. Using an ohm meter, measure the fuse for 1 ohm or less. If the reading is considerably high, replace the fuse. If the fuse is blown, inspect further for the cause to avoid the fuse blowing again. Inspect for damaged gear motor wiring or a bad gear (elevation/incline) motor. Replace if necessary.
  2. Thoroughly inspect the home switch wiring for damage or intermittent connections. Repair or replace damaged wiring or poor connections as necessary.
  3. Thoroughly inspect the gear (elevation/incline) motor wiring for damage or intermittent connections. Repair or replace damaged wiring or poor connections as necessary.
  4. Ensure the moving arm is away from the home switch and disconnect power from the unit. Disconnect both wires from the home switch. Using an ohm meter, check for approximately 0 ohms. Continue to monitor the home switch resistance and activate the home switch by hand. The reading should change from approximately 0 ohms to open (infinite). If either reading is considerably incorrect, replace the home switch.
  5. With unit disconnected from power, disconnect both wires from the gear (elevation/incline) motor. Using an ohm meter, check for approximately 9 ohms through the gear (elevation/incline) motor wiring. If the reading is considerably high or low, replace the gear motor.
  6. Inspect the gear (elevation/incline) motor target for rips, tears, or bad scratches. If any of these are found, replace the target.
  7. During the start up sequence, check the voltage at the gear (elevation/incline) motor. Voltage should be approximately 12VDC. The voltage should only be present between the time the sequence was started and the error 53 occurred. If the voltage is considerably low or absent and the F2 fuse proved good, replace the lower PCA.
Precor Error Code 53
Nov 02, 2013 | Cars & Trucks
I have a PVS12DT Personal Viewing System, Integrated Controller out of a precor exercise machine I am trying to repair for a friend. the problem is garbled screen and has a vertical roll. I cannot even...
The tuner inside the unit has most likely gone bad. I've seen a lot of these units do this in the last year or so. Precor use to refurbish these on site but they discontinued the program. If a tuner goes bad in one of these they want you to replace the whole viewing system now
Aug 30, 2013 | Precor Exercise & Fitness
Precor treadmill error L5
Corrective Action
Feb 25, 2012 | Precor 935 Premium Series Treadmill
Sport & Outdoor - Others Logo
50 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
