Question about Whirlpool LER4634J Electric Dryer
My whirlpool dryer has a black switch in the upper right hand side of the door that seems to have broken. now the dryer doesn't start (I'm almost positive there is some sort of electrical connection issue due to the swtich). have you seen this before?
  • 5,911 Answers
You are referring to the door switch. This will definitely keep the dryer from running. When the door closes, the switch also closes, which provides an electrical path to the timer, switch and start motor. If the switch is broken, the dryer will not run. You will need to open the dryer to access the switch to replace. This is accomplished by lifting the top panel and/or removing the dryer front.
If the model number is correct, just follow these steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the dryer top panel.
3. Locate the door switch and unplug the connector plug. Remove the mounting screw(s) that hold the switch in place. The part number for a replacement switch is 3406105.
Replacement parts can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also inlcude helpful exploded view diagrams that can help you locate and properly indentify the parts you may need.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
Posted on Jul 07, 2010
How to Replace a Dryer Door Switch on a whirlpool
First, make sure the peg on the door that pushes the switch is in place and the two snap pegs that hold the door shut are not broken. If any of these are broken, replace them first and see if that solves your problem. If not, here's how to replace the door switch: Unplug the dryer. Pull out lint screen. Remove two screws revealed underneath. Slide a 1" putty knife between the top and cabinet at the top front corners on each side, jamb it in while tugging the top forward to release the clips, one at a time. Lift top and lean against wall. If it's a gas dryer, remove lower front panel and loosen two 5/16" hex head screws for top front panel. If electric, loosen same screws at bottom of front panel. Remove two 5/16" hex head screws holding front panel from inside near top. Carefully tilt front toward you, holding drum in place. Lift front panel slightly to disengage bottom screws and remove. Gently lower drum until it stops. Unplug two (sometimes three) wires to door switch on right side. Now the front panel is completely free. Remove two Phillips head screws holding door switch onto front panel. Reassembly is the reverse of disassembly. Make sure wiring to door switch is secured to cabinet so they don't drag on the drum, and are not pinched. Be careful realigning the drum into the door opening so felt seal is inside the front glide ring on the drum. After the front panel is in place, gently hand turn the drum to make sure it is turning properly and the belt in still hooked to the idler and motor pulleys. If the drum falls off the rear rollers, or the belt comes loose, you will have to correct it before putting the front panel back on, as you cannot reach them otherwise. Taking pictures during disassembly will help get it back together properly. It really is not as hard as it seems, you may even be able to replace the switch without removing the front panel. Also, if you have a three wire switch, write down where they go or snap a picture. If it's a two wire switch, it doesn't matter, it will work the same either way. Good luck.
Feb 18, 2014 | Whirlpool 358409 Washer/Dryer Screw &...
Replace starter switch
Putty knife to release the top then lift the top off there. I ain't never seen a start switch break yet. Your fuse is probably gone or door switch broken. Start switch nawsir. Rare.
Small disk on rear upper right hand corner is the fuse. If open the dryer will not operate.
Jul 10, 2012 | Frigidaire FEQ1442ES Electric Dryer
Model Whirlpool le8650. My dryer stopped working. I noticed the brass clip in the upper right corner just above the door had broke off. I locaated 2 screws that were holding the part that was broken. I...
Unplug the dryer.
Remove the lint filter.
Remove the 2 screws at the lint filter slot.
Place a flat blade screwdriver under the front edge of the top and pry it up. Remove the 2 screws holding the front panel to the cabinet on the right and left sides just inside the cabinet.
Replace the door switch assembly and reverse the above order to re-assemble the dryer.
Sep 19, 2010 | Whirlpool Dryers
After I push start button sensing light turn on,but dryer does not work,just click.
sounds like you have a broken belt
first remove the lint trap
remove the 2 screws
unplug the dryer from wall
lift thhe lid
you will have access to the drum
is the belt still in tact
if you cannot see the belt that is you problem
another option open the door you have a door switch in the upper left or right corner
when you close the door, does the door hit the switch ?
if not you have a bad lid switch
which you can gain access to it the same way as the above to access the belt
Aug 24, 2010 | Whirlpool LER4634J Electric Dryer
I have a whirlpool LP Dryer model #LGR5848E that won't start.
can you turn the drum by hand.
if not i would be concerned that you have a sock or something stuck in the blower sqiral cage.
if you can turn it by hand and it sspins freely, then you may have several issues, broken belt, is where id start,
the fact that you can hear a hum say the motor is trying
Oct 05, 2009 | Whirlpool Dryers
The dryer will not turn on.
Well, thats the door switch. Probably the plastic locking flanges that holds it in place are broken off allowing it to fall back in the cabinet. The flanges and switch are one in the same part itself and not very expensive, but you have to remove the top deck of the cabinet to access the switch/wiring harness and render replacement efforts. You can purchase the part thru Sears/Kenmore by giving them your Whirlpool model number. Once you have the part, be sure to unplug your machine first before attempting this! Safety first!
Dec 18, 2008 | Whirlpool LER4634J Electric Dryer
Dryer problem
the door switch is bad. $16.65 Item #
528948 at repairclinic.com
Jul 12, 2008 | Whirlpool LER5636P Electric Dryer
Doesn't work at all
Check the door switch. With the door open, on the upper right side of the tub opening there should be a little lever. Push on it and you should hear a click sound. If the lever is broken or no click sound, you need to replace the switch. If that checks good check your circuit breakers and power cord and outlet.
Apr 08, 2008 | Kenmore 63032 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
50 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
