Question about Samsung HCM4216W 42" Rear Projection Television
Red blinking light
I have a TV (SAMSUNG=HCM4216W) and everytime Itry to turn it on all I can see is a red blinking light next to the timiing warning light, 'any solution?,
Thakns a lot, oefrain@yahoo.com
  • 1 more comment
  • wazaaaaaam Apr 23, 2008
    my tv doesn't turn on the red light blink nothing happend any idea
    thanks,
  • captainq Jun 15, 2008
    tv turns itself off intermitantly but will come back on if you press the power button a couple of times.
  • cfoy32707 Apr 19, 2009
    I disconnected the wire described still nothing but the blinking light and a electrical heat smell are there and other diagnostics that can be run ? Thanks
  • 934 Answers
It's most likely convergence -- the small board up and to the right inside the back of the TV, which has two large amp Ic's attached to it..
Unplug the +/- 20v line on the fron left corner of that board (red in color) and then try and power on the set... If the set comes on the board needs to be repaired and it's an easy unplug and two screws that mount it inside.
Bill
Premium Technologies
PO Box 442
LOng Beach, WA. 98631
360-641-4993
premtech@willapabay.org
Posted on Jun 15, 2008
Samsung HLS4266WX/XAA warnings w/ new lamp also
You may be in need a new ballast, the assembly that excites the bulb into producing output.
Sep 20, 2017 | Samsung Televison & Video
Turns on, no picture or sound, light blinks 5X, reboots itself
First thing is to check the lamp. you can easily change this yourself.
May 26, 2009 | Samsung HCM4216W 42" Rear Projection...
Blinking red fault warning
timy check the speaker conections before condeming the amp
Apr 30, 2009 | Crown CTS600 2-Channel Amplifier
Samsung hcm4216w won't turn on light blinks then shuts down and tries to restart again
Your problem is TV is not getting enough power so you better buy a stabilizer and make the power to go thro the stabilizer to TV then it will get sufficient power supply everything will be smooth afterwards even the voltage problem.
Oct 17, 2008 | Samsung HCM4215W 42" Rear Projection...
Timer Light.
according to the book hcm4216w says ti will blink 10 times when turned on then then iluminate when on
Jul 20, 2008 | Samsung HCM4216W 42" Rear Projection...
TV does not turn on.
No sound means it could be a ballast issue. If there is sound, it could just be the lamp.
May 18, 2008 | Samsung HCM4216W 42" Rear Projection...
Studioseries (samsung) 42" rear projection tv red duoble outline of picture
sounds like the red convergence Ic is weak ready to go out. try replacing the ICs around 10.00 do the blue as well as that will be next.
Mar 18, 2008 | Samsung HCM4216W 42" Rear Projection...
Samsung hcm4216w
The most common problem for those symptoms are convergence amps. That unit takes two stk392-040 Sanyo Ics and will most likely require that several low ohm resistors (3.9 ohm-2w) be tested and possibly replaced.. There is one last thing also, a pico fuse at Fd102 (3.5a) that sometimes opens and would need to be replaced..
The convergence board in these is easily removed, so an in-house service call could be done...
Hope this helps
Jan 09, 2008 | Samsung HCM4216W 42" Rear Projection...
Samsung HCM4216W 42" Rear Projection Television Logo
257 people viewed this question
Jerry Greenberg
Jerry Greenberg
