Question about Gateway GT5058 Desktop PC
Replaced Gateway 105552 Foxconn C51GU01 Motherboard with another Gateway 105552 Foxconn C51GU01 Motherboard and nothing works except cpu fan and power supply fan when i turn computer on it is a gateway gt5058 computer
  • 487 Answers
Hi, you will need to do a complete re install of your operating system. If you require help with this come back to me, regards.
Posted on Jul 07, 2010
2 Suggested Answers
  • 61 Answers
SOURCE: replaced Gateway 105552 Foxconn C51GU01 Motherboard with another
Are you sure it is a good MB? If so double check all connections and try again. If you still have problems post back and let me know if you are getting any beeps at startup.
Posted on Jul 09, 2010
Need mobo manual
Hello you can download a manual here:
http://support.gateway.com/support/drivers/search.asp?st=pn&param=105552
The homepage is here:
https://support.gateway.com/s/MOTHERBD/FIC/105552/105552nv.shtml
And sorry for the slow responce.
Good luck
Oct 18, 2012 | Gateway Foxconn C51GU01 Motherboard
I was running a gigabyte MB ,.then powr supply failed baddly,.. I purchased a used foxconn MB and diffnt PSupply,..I put the CPU on foxconn MB and mounted in old case w/ what I think is good PSupply,.. but...
did you connect the cpu fan and fan 1 power feeds in on motherboard ?
from
http://www.foxconnchannel.com/driverdownload/Motherboard/Intel/Socket478/661FX4MR-ES/manual/English/661FX&648FX4MR-Eng-easy%20guide-09-04-04.zip
Sep 05, 2017 | Foxconn 661FX4MR-ES Motherboard
Jul 07, 2010 | Gateway GT5058 Desktop PC
Gateway Foxconn C51GU01 (105552) Problem: blue
Possible a memory socket is bad. Make sure you are using the correct type of memory including parity and compatible speeds. It is recommended to use like memory sticks in each slot. Some PCs even require the sticks to be equal memory capacity. User's guide should tell you what the compatible capacities and speeds should be. If you don't have the manual, you can get by looking up your PC model number on Gateway.com.
Bret
1-2-1ComputerServices
Oct 04, 2009 | Gateway GM5084 PC Desktop
REPLACE FAULTY CPU CELERON 3.06GHZ WITH PENTIUM 4 CPU
Your motherboard specs are at http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000152
Looks like you could go up to a 3.8GHz P4, make sure you get a fan that will cool it properly.
Dec 28, 2008 | Foxconn 661FX7MF-S Motherboard
Bad motherboard in a GM4019E by Gateway
Board measurements are not industry standard so you might be stuck getting another Foxconn board. Sorry.
Dec 21, 2008 | Gateway GM4019E PC Desktop
Foxconn mobo
try to look on the jumper settings on the motherboard before you upgrade your proccessor maybe they need to be adjusted.tryb to put back the one wich was there and see what happens.how many beeps does your computer makes when you switch in on?if it makes more than one then your proccessor is not compatible with the board.a computer should beep once whenevever its switched on
Sep 06, 2008 | Foxconn 945GZ7MC-RS2H Motherboard
Memory
Hello.
Of course it would be a great improvement, but unfortunatelly you can't install DDR2 in DDR slots, they are different and even if you could make it fit they have a big difference in architecture.
i'm sorry, it wont work.
Regards
Jul 13, 2008 | Gateway GM5084 PC Desktop
Gateway C51GU01 MOTHERBOARD (no video)
I supose you should test the capasitors one by one.
Faulty capacitors :
http://www.asti-usa.com/support/appnotes/65/2.jpg
if the capacitors arent flat they are possibly bad note in the picture the blue / black capacitors are flat. the black orange capacitors all seem bad. the two are bad for sure.
Apr 04, 2008 | Foxconn 865A01-PE-6EKRS Motherboard
Gateway GT5058 Desktop PC Logo
473 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
