Question about Xerox Phaser 3124 Printer
Theres a toner status "toner Low" but I've just changes my toner.. In about 2 days that status pop out again.. a print about 30 pages for a day.. Whats the problem?? Do i need to restart toner page count? how?
I had the blinking problem as well, but the printer prints fine even it's blinking....
Posted on Sep 03, 2010
LexMark e321 printer is printing blank pages. I changed out the ink toner, reinstalled the driver from the E321 disk, changed the USB cable and still get 2 blank pages and the LED button by error is...
Try to disconnect all cables from the printer and leave it off for about 30 seconds to clear the print job. Turn the printer back on and check the status lights, error light stop blinking then try connecting the printer back to the computer and try printing again.
For further assitance, please contact Lexmark Technical Support
Jul 20, 2011 | Lexmark E321 Laser Printer
When i refill toner it still show toner low.how sovle the problem
Good day.
First try to print a print status report. Here are the steps:
1.Push setup menu button, that would be the wrench icon. 2.Push the right button to navigate until you get to the Tools Menu 3.Tools Menu>Push button for Printer Status Report
This will give you the accurate ink levels on your printer. If it still shows low ink based on the printer status report, you have to reseat the ink cartridge and make sure the orange tape near the HP Logo on the ink cartridge has been peeled off.
If the report shows ink levels are fine, then that status report on the front panel is just a false report. Try powering off your printer and powering it back on again. As long as you don't have print quality issues, you should be fine.
Jun 20, 2011 | HP LaserJet CP1515n Printer
Light copies
One of three issues --
1/ Toner is about out.
2/ Fuser needs replacement.
3/ Darkness setting is too low.
3/ Go to the configuration menu and raise the darkness setting.
1/ Check to see if your toner is low. Again go to the control panel and navigate to the status page
and print out a page. It will give you the % left of toner.
Mar 23, 2011 | Samsung SCX-6345N Printer
Shadow printing in hp laserjet 2600n
Hello jagdishgolas!
Theres a few things you need to do first to determine what its causing the problem
Here are some steps you can follow:
1) Print a Supply status report (Main Menu > Reports > Supply status)
If you still see the shadowing is on this page we can tell that the problem is not on the computer
Check toner level on this supply status, if its showing lower than 10 % i would recommend to replace the cartridge
2) Run 3or 4 Calibrations in a row (Main Menu > System Setup > Print Quality > Calibrate Now)
3) Run 2 cleaning modes ( Main Menu >Services > Cleaning Mode)
4) Access the secondary service by hitting the checkmark and the cancel button at the same time, then hit the checkmark again
Under the secondary service look for "Clean Belt" anr run it twice
Try printing again
Heres a link where you can find an Authorized repair center near to your location :
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
Jun 21, 2010 | HP Color LaserJet 2600n Printer
I havean HP 2600n, anything red prints in a faded yellow. I've seen other posting regarding this put all answers suggest something wrong with the printer. However, when I had a supplies status page...
change the cartridges. Theres nothing else that can alter the color like that without rewriting the drivers. B4 you do, take each one out, shake gently from side to side to even out any toner, and try again.If they print better, your toner is low.
May 26, 2010 | HP Color LaserJet 2600n Printer
Brother HL 5150D not printing unless I keep pressing Go
its not the problem of toner cartridge.its the problem of gears which pulls the paper they r worn out or may be cracked internally.exactly what happens when you u give the print for the first time the printer gets command and the gears starts spinning and the paper gets pulled because it gets a pressure internally and after 2 pages that pressure gets low and it stops pulling the paper.some times changing the paper thickness solves the problem temporvarily .i mean use the thick quality paper instead of thin.
Jan 08, 2009 | Brother HL 5150D Laser Printer
Samsung CLP 510 light grey vertical streaks
you have 2 problem.
1). toner is bad
2). toner is low
change the toner should fix both porblem.
try to clean the roller while you have the toner out. (just in case).
Mar 27, 2008 | HP LaserJet 5p Printer
Out of toner........ but not really.....
Print a Supplies Status page to see the actual pages printed...
To print the Supplies Status page from the printer, on the printer control panel, select
Reports Menu, Supplies Status, and then Print Supplies Status page.
If the page count from the Supplies Status page indicates that the toner should not be in need of replacement then you have a bad cartridge. Actually, the cartridge is probably fine but the chip on the cartridge has got a problem. Return the cartridge to O.D. and get another one. Unfortunately, chips that don't work properly in not all that unusual so HP has a pretty easy return policy.
Hope this helps.
Mar 07, 2008 | HP Color LaserJet 2600n Printer
Had it a while and it stopped working.
Come on copier tec you should know better, need to know which light is showing orange, Drum,toner,paper,status?
Intuition tells me that you have a orange toner light and a red status showing, and you are using a non OEM toner, but thats guessing.
Dec 26, 2007 | Brother HL 5140 Laser Printer
B4100 - Yellow Light
U can have stuck a little piece of paper, that it mess whit some sensor. Try to open the Oki, push the drum unit out and watch if there is no paper stucked.
Nov 26, 2007 | OKI B4100 Laser Printer
Xerox Phaser  3124 Printer Logo
389 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
