Question about Electrolux Refrigerators
Electrolux 3 way fridge will not work on 12v or 240,switch lights up, ok on gas. can i repaire?or have i got to replace? i think the model No is rm4200 or rm4230
  • 3 Answers
Hi My three way fridge has the same problem. Have solved the 12v problem as it was not wired to the 12v invertor. Do you have an on board battery supply? the 12v is usless and runs a battery flat in no time. Better off to use gas. Hope to have the electrician here next week to check 240v so will let you know if we find a problem. Graham.
Posted on Nov 13, 2010
  • John Dec 27, 2011
    Check that the 12v is getting to the heater element and that the selector switch is working ok.
    Resistance of the 12v heater element is about 10 ohms so a meter should show if this is ok.
    My fridge suffered a loose cable connection which blew a hidden fuse (in the engine compartment and unmarked).
Have carervan with electrolux rm2330 3 way fridge will not work on 240 and 12v
if works on LP then replace heater elements for electric or possible bad control board
Jan 10, 2017 | RVs
Dometic 3way fridge model RM2350R. the fridge works ok, but when i run it on gas the flame lights first time, but the flame indicater does not work,the thermocuple has the right ajustment,is clean,wh
The flame indicator works on very low voltages from electricity generated via the thermocouple. Check the connections and if OK, I would say you are correct in assuming the indicator has failed. These are very sensitive and a bit of a knock can damage them. Try Dometic or Electrolux for a replacement indicator.
Nov 21, 2014 | Dometic Refrigerators
Electrolux siegen ghbh 3 way fridge model rh275 stopped working on gas but works on 240 volt
check that some bugger hasn"t turned your taps off or gas bottle -otherwise call a camper trailer dealer and ask the the best advice on what to do -might just be a blocked gas jet -but you will need a licensed gas fitter to check it for you -wont cost too much
Aug 07, 2014 | Electrolux Refrigerators
I have a 2453 150 litre caravan fridge not working on 240 but works on gas. What maybe the problem and can i get a mobile repairer
It sounds like the electric heater is not working as you say it works on gas, so the expensive bit is OK.
An appliance engineer should be able to get the spares and fix it.
Mar 07, 2011 | Microwave Ovens
Camper fridge does not work on gas.
right where the gas comes out there is an elect igniter do you see or here it clicking some times carbon buildup causes it to ground out inproperly sometimes the bracket gets rusty the bracket needs to be able to fire a spark directly twards the jet good luck
Apr 12, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Hi i have a 3 way electrolux fridge. it cools perfectly well on the electric mains, I've not tried the 12v, but it fails to cool on the gas. The gas ignites but fails to cool the system.
A simple remedy to the fridge working correctly.
I wasnt aware that the mains dial turned fully to an 'OFF' position. Once I had turned the dial until it 'clicked' off, I tried the gas and it lit and cooled perfectly.
May 28, 2008 | Electrolux Refrigerators
Refrigerators Logo
418 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
