Question about Canon imageCLASS D860 All-In-One Laser Printer
Paper Feeder There is a piece of tape stuck in th feeder. We were able to see it but one of our employyee tried to removed but pushed it down where now we cannot see it.  How can I fix it or get the tape out. Thanks
  • JCalJr Aug 15, 2008
    I had a paper jam and I removed the piece that was stuck but I am still getting the same error. "Rec paper jam slide platen to left". I think all the pieces are out. Could there be another solution besides turning it off and turning it on?
  • Realtorjohn Sep 02, 2008
    shreds of paper exist where the copied sheet would normally exit. Tried to turn the white plastic wheel behind the copier cartridge, can't turn it. Tried to pull out the shreds of paper...they won't come out. Copier no longer functional.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
If it's causing a jam then you're going to have to take it apart
Posted on Jul 21, 2008
How do I get a stuck piece of paper out of top feeder?
the top feeder is supposed to be able to open giving you complete access to the workings of the top feeder
and also when removing the paper work gently, and check to see if you removed the complete page and that a piece hasn`t torn off and is still stuck inside
Mar 04, 2014 | HP Officejet Pro 8600
Document feeder error message
did u guys ever use maginzes to scan documents with they will get jamed in there i would open it up cheak feeders closly ok thx nick
Feb 09, 2008 | Office Equipment & Supplies
Need to remove piece of shredded paper stuck in the c309a ADF but can't unscrew the screws.
This video will show how to remove a part to get to a stuck piece in your printer's ADF. Hope it helps:
WP_20170601_002.mp4
http://www.303electronics.com/
May 29, 2017 | HP Photosmart Premium C309A All-In-One...
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    A small screw dropped into the top feeder of my Canon Pixma printer. I have tried holding the printer upside down and shaking it, nothing comes out. When I try printing from the top feeder, the paper jambs...
    Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
    First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
    If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Feb 06, 2010 | Lexmark X4650 InkJet Printer
    It says there's a paper jam or a scanner misfeed..but there's nothing there
    Paper stuck inside the HP All-in-One can cause jams or also sometimes there are some instruction that get stuck in the printer internal mechanism .
    Power off the printer , unplug the power cable. Wait for 30 sec. , Replug the power cable. Power on the printer.
    Check for a stuck paper or torn bits of paper.
    Clear jam from the back of all-in-one
    Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One.Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
    Gently pull the paper out of the rollers.If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the HP All-in-One, more paper jams are likely to occur.
    Replace the rear door. Gently push the door forward until it snaps into place.
    Press OK to continue the current job.
    Clear the jam from the automatic document feeder (ADF)
    Paper can also jam in the automatic document feeder. Follow the steps below to clear a paper jam in the automatic document feeder(ADF)
    Lift the cover of the automatic document feeder.
    Reload and test the all-in-one
    Once you have removed the jammed paper, verify that the all-in-one is still functioning properly.
    Reload the all-in-one with either plain or photo paper.
    Print a page from a memory card or the computer.
    If you have completed all the steps listed above and are still experiencing a problem contact HP to service the product.
    Jan 24, 2010 | HP J3680 Officejet All In One Printer
    Paper won't feed into printer
    I have taken a piece of cardboard, like the ones you get with a new shirt, size it to 8.5 x 11, and tell the printer to print a test page. hand feed the cardboard thru, and most times it will clean out the residual paper pieces stuck in the internal rollers. I have used this method several times and was successful 99% of the time. It isn't rocket science, but It may work. You will probably have to push the cardboard thru, but do not force it to much. It will not go thru easily on its own. Just a suggestion.
    Jun 17, 2009 | Epson Stylus CX3810 All-In-One InkJet...
    Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
    Please try this
    1. Turn off the printer.
    2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
    3. Also open the back cover of the printer if this model has one.
    4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
    5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
    6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
    8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
    10. see alternative if the problem is still not solved.
    alternative :
    Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
    Jun 09, 2009 | Lexmark T644 Laser Printer
    Jam in the document feeder
    get rid of that hp piece o crust. demand your money back.
    Mar 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
    Auto document feeder
    Did you make sure the tape is removed inside the Document feeder,or maybe you need to check to see if anything is stuck in the rollers. Open the door (if you have not already done so) to the document feeder and you will see pictures on the inside showing how you can remove and/or change the roller (make sure everything is put back as the picture. Good luck, I hope that is all that is wrong with it.
    Dec 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
    Canon imageCLASS D860 All-In-One Laser Printer Logo
    76 people viewed this question
    old marine
    old marine
