Question about Hampton Bay 24002 Ceiling Fan
I need the speed switch wiring diagram. - Hampton Bay 24002 Ceiling Fan
Need a wiring diagram
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 20, 2016 | Exercise & Fitness
Need wiring diagram for speed control switch. Northern Tool doesnt have it
No diagrams here! Do an Internet search using Yahoo or Google, and check for diagrams available manufacturer's website.
May 12, 2015 | Cars & Trucks
I need to check a fan control switch
Did you check for voltage and ground at the blower motor connector? You may be way ahead of me? Different speeds are controlled on blower motor ground circuit. In the diagram, the top wire at blower motor is voltage and the bottom wire is ground. The diagram may not be what you wanted? Brown is voltage, orange is ground at blower motor. Maybe you can hit control and plus on your key pad to enlarge diagram.
Mar 04, 2015 | 2005 Chevrolet Colorado
Westinghouse fan wiring diagram
Copy following link for general assistance wiring 4-wire ceiling fan switch:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Jul 14, 2012 | Electrical Supplies
How do I get the wires out of the old 3 speed ceiling fan switch so I can replace it with a new one?
Usually, there is no way to remove the wires from the switch. Turn off the circuit breaker that powers the circuit going to your fan. Then, match up the new switch with the old one to make sure you have the correct one, with the correct amount of wires. Mark the placement of of these wires with masking tape or draw yourself a diagram. Next, you need to cut the wires as close to the old switch as possible, and strip back about 1/2" of the insulation on these wires. Now connect those wires to the leads (wires) coming from the new switch with small wire nuts or crimp fasteners. When connecting the cut wires to the new switch leads, follow the same pattern as the old switch (refer to your masking tape labels or your diagram). Now you can secure the switch to the fan casing with it's locknut, and carefully tuck the wiring back inside. Re-secure the casing to the fan.
Aug 01, 2011 | Speed Ceiling Fan 3-speed Switch By...
77020 fan switch dont turn off. i need a diagram please...
Copy following link for wiring 3-speed fan switches
May 25, 2011 | Speed Ceiling Fan 3-speed Switch By...
I PUT IN A 3SPEED FAN SWITCH I GIVE IT A PULL FOR THE 3 SPEEDS BUT I CAN'T TURN IT OFF HELP
Check your wiring and the diagram that come with the switch... You might have the Hot Wire (power wire... usually black in color) wired directly to the motor.
Normally the switch will have a common wired....which should be the hot wire...then it should have a wire for each speed. Double check your wiring and wiring diagram. I'm Sure It was just a small oversite.
Make Sure You Have The Power Off While Working With ELECTRICITY!
Feb 18, 2011 | Dryers
Got a new switch...need a wiring diagram..oster a5 two speed
I have found the wiring diagram that you are looking for. Go to http://www.clipperparts.com/schems/oster/professional%20clippers.pdf
I believe you are looking for the diagram on page 18. Hope this helps.
Apr 14, 2010 | Oster Golden A5 2-Speed Universal Motor...
Hampton Bay 24002 Ceiling Fan Logo
174 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
