Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Have a 37MF321D 37" Magnavox. Will not power up . No green light or anything. Power cord is fine.
  • tfisher4159 Jul 07, 2010
    Have a 37MF321D Magnavox TV- Will not power on. Have noticed by plugging it in that the master/voltage invertor board will lite up (D24) brite blue for a second and than shut off. Power supply board appears to be fine. Power cord is working.
  • Philips Master
  • 6,993 Answers
your TV is having a power problem. The power board is defective, that's why there is no power on the TV.
Get a screw driver, open the TV cover to gain access to the power board, check for any blown fuse.
You need to get a meter, read the power board of the TV, in other to detect the bad component (capacitor, diode, transistor etc.), make necessary replacement and the TV should power up again.
The fault is mainly a power problem, so the power section of the TV needs to be diagnosed.
Posted on Jul 07, 2010
  • tfisher4159 Jul 08, 2010
    I noticed the small fuse on the power supply board. Would I be able to tell that it is blown as it has a white wrapping around the middle part of the fuse.
  • Walesarumi
    Walesarumi Jul 08, 2010
    you can test it with a meter. This is how you will be able to tell if the fuse is bad or not.
    Take care.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You’ll need to reset it. To reset the TV turn it off and wait for 5 minutes. After 5 minutes unplug the television power cord from the electrical outlet and let the television remain without power for more then 1 minute. Plug the power cord back into the electrical outlet. If the television is plugged into a power surge protector, remove it from there and plug it directly into the wall outlet. Turn on the television. If the issue is resolved, then the problem is with the power surge protector and not the television. If the issue is not resolved then this might have happened due to over-voltage. Please check the power supply unit for swollen/ bulged capacitors and burnt wires/components on the power supply board. Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in off condition. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • 2 more comments
    inspected the power supply board and there is no appearent problems with caps or wires. TV would not reset with this solution. Could it be in the power supply board? Is there a crystal?
  • Rylee Smith
    Rylee Smith Jul 07, 2010
    If the capacitors on the power supply board appears
    to be working fine and not bulged/swollen on top then check the main board
    which is the another board where all the power plugs into. Please do accept the
    Thanks
    Rylee
    Noticed the small board that has power going thru it, the D24 lite up brite blue for about 3 seconds and kicked off. Board # 6632L-0282A
  • Rylee Smith
    Did you check/test that board, if yes then replace the component that has gone bad.
Magnavox 37MF321D/37. suddenly just shut off and would not turn back on, no blinking green light nothing!
Price the board first and then decide, I fix these in our shop but do not like or enjoy working on them at all.
Dec 20, 2012 | Toymax Magnavox 37MF231D 37 in. LCD TV
Magnavox 37MF321D/37 screen flashes with no pic, power light steady, capacitors in power supply look to be fine
I just fixed a similar problem on mine but the power light was flashing at the same time the screen was flashing. I made a video showing what part and how to replace it. I also added a link to the part I ordered. L5973D STMicroelectronics Mouser
May 22, 2012 | Philips 37MF321D 37 in. LCD Television
37MF321D/37 TV turned off last night. This morn, won't turn on
Please read these replies to the same problem. A new power board costs around $284.00..
http://www.fixya.com/support/t465280-magnavox_37mf321d_37
Jan 01, 2010 | Philips Magnavox 42MF521D/37 Television
I have the same model 37MF321D/37 and the Blinking Light
I fixed it by replacing the two capacitors with 3300uf 25v instead of Magnavox's 3300uf 10v and a power swith that I ordered from http://www.encompassparts.com/. Also I did have a power supply put in from a repair place that cost $160.00. It is working perfect now and no blinking light.
Sep 20, 2009 | Philips Magnavox 42MF521D/37 Television
My magnavox 37MF321D/37 will not turn on. It
I had the same problem with the blinking green light. These are the parts one the power supply I replace to repair it. note: If the power supply is repaired you will get a solid green light and the backlight will light up almost immediately.
Aug 01, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 37mf321d/37 TV has no audio or video . Green light comes on but then goes out . Kind of like it want boot up.TV is 2yr old and last 10 times it took a long time to come on .I have onyko surround...
This is a internal problem,,,You need a repair
Please don't forget to rate me "FIXYA"...thank you!
Mar 04, 2009 | Televison & Video
Magnavox 37MF321D/37 flicking on & off
Sounds like you need to repair the power supply, don't fret, it can be really easy.  Here is a pair of youtube videos I made after following some advice on this website from other posters:
http://www.youtube.com/watch?v=qSS6ycUxS98
http://www.youtube.com/watch?v=oTOkHKPJsnM
Feb 08, 2009 | Philips Magnavox 42MF521D/37 Television
Not powering up right away
This is a big problem with these tv's. Magnavox built them with undersized capacitors, and they blow. You have to open the back, remove the power supply and replace the capacitors numbered 2074 and 2081. This sounds like a real tech job, but read my other solutions, and you will see it is not so hard. Good luck.
May 28, 2008 | Philips 37MF321D 37 in. LCD Television
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
205 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
