Question about Audiovox Xpress EZ XM Satellite Radio Receiver with Vehicle Kit
The word antenna keeps flashing - Audiovox Xpress EZ XM Satellite Radio Receiver with Vehicle Kit
SONY KV36FS76U WONT TURN ON JUST KEEPS FLASHING RED/GREEN LIGHT
I think you tv is required to have an interface attached to it. Such as an antenna, or cable line, or game system. It's like telling you "there is no reason for me to turn on, there is nothing connected!"
May 28, 2014 | Video Game Consoles & Games
I changed the battery in my remote now my car will not respond
Reprogram the remote: press and hold the f button for approximately 8 seconds. the remote will flash three times. press the remote start button on the remote. the remote is now ready to pair. enter vehicle, turn ignition on, press and release button and antenna, immediately press and hold same button, the vehicle should respond with a horn honk and/ or light flash on antenna. While holding button on antenna, pres lock button on remote...vehicle should respond with a confirmation horn honk and/or light flash. Release button on antenna, turn vehicle off. Test system.
Jul 12, 2012 | 5101 LE 1 Way Car Remote Starter System
Magnum s980 SWR Light Flahing on keyup
Get your hands on a Dummy load and see if same issue--if not when RF hits the line a short exists (connector, coax, or antenna)
If same issue with a dummy load it may be in the radio if it has the SWR light the circuit may be reading wrong.
Apr 09, 2012 | Radio Communications
I have a black double antenna xbox 360 wireless adapter and it keeps flashing green and then logs me out. help please?
may need a update....so leave your wireless hooked up and hard wire your xbox to the net to get the update.
Dec 27, 2010 | Microsoft Wireless Network Adapter Xbox...
WAS WATCHING TV AND IT WENT OUT
check ur antenna connection....to ur tv,,,,,also check antenna and cable.....if problem keeps on going go in touch LG customer service
good luck
Mar 06, 2009 | LG 50PC3D 50 in. Plasma Television
1991 jaguar xj6 RADIO couldn't turn ON! The radio can't turn its power on by the switch, the security indicator keeps flashing all the time no matter the switch is "ON" or "OFF". the fuses are good and the...
1991 jaguar xj6 RADIO couldn't turn ON! The radio can't turn its power on by the switch, the security indicator keeps flashing all the time no matter the switch is "ON" or "OFF". the fuses are good and the relays that I COULD find (in the trunk for the antenna) are good as well. I have power GOING to the radio from all indications but it doesn't come on or flash CODE for me to enter, which I do have. Is there something I'm missing or is the radio just shot? Also I found no fuse on the radio it's self. Is there some SIMPLE fix out there? Or should I START SHOPPING?
Thanks.
Jun 15, 2008 | 1993 Jaguar XJ6
Internal antenna
mine does the same thing....i even have the external add on antenna, mine turns on fine but as soon as you flip the antenna up on the back, the screen starts flashing and the system keeps rebooting over and over again...
May 11, 2008 | Garmin iQue 3600 GPS Receiver
Our Mitsubishi Big Screen HDTV connected to an antenna
can you post the model number of the set? Also is the picture going out to a black screen or a colored screen. Please elaborate if possible and I should be able to help you.
Apr 10, 2008 | Televison & Video
"No Signal" Keeps Flashing on the Screen
I would suspect you have a weak or intermittent source. If it is cable, you may want to have them check it for you. If you are using an antenna, you will want to get a better one or at least try a different position.
Dec 20, 2007 | RCA 14F512T 14" TV
Audiovox Xpress EZ XM Satellite Radio Receiver with Vehicle Kit Logo
102 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Chinmay Joshi
Chinmay Joshi
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
