Question about Coleman Mach III Air Conditioner
HOW TO RECHARGE THE FREON IN A COLEMAN MACH AIR CONDITIONER
TEMPERATURE OF AIR IS LESS COMING OUT OF UNIT and Takes longer to cool down ... air condition guy sez it is a sealed unit and cannot be recharged??? ... ALL NEW FILTERS ETC ETC..
4 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Recharge My AC Unit
The system needs to be accessed through what is call a tap valve. After a tap valve is in place a high vacuum should be pulled on the system down to 500 microns to remove air and non condensible gases along with any moisture from the system. Then the charge should be weight into the system according to the name plate with the proper type of refrigerant, generally Refrigerant 22. An alternate method is to charge the system by superheat of the gas returning to the compressor. Ambient temperature determines how high or low the superheat should be.
Posted on Jun 20, 2008
heavymetal77
  • 721 Answers
SOURCE: air conditioner does not cool
Well, letting things sit that long isn't good for them. It probably lost it's charge of freon.No way to fix that.
Posted on May 04, 2010
SOURCE: Where are the air filters
The filter is under the bed in rear.
Posted on Nov 07, 2010
How to do a freon recharge on roof top rv airconditioner
there are no access ports to add freon you would have to put a line tap valve on it.
May 10, 2014 | Coleman Mach 15 Air Conditioner
I have a 2010 30' cougar travel trailer, we have never used the air conditioner which is a coleman mach model, when I put it on auto and cool it blows cool air but never gets cold am I suposed to
Check the temperature of the air coming out the vent If it's more than 10 degrees below the air going in it's ok. If it's the same temperature, the condensing system may be not working. The compressor may just be a quiet one!
May 18, 2012 | Coleman Mach III Air Conditioner
How to add freon to a coleman mach model# 8633-876 serial # 089817583 do you suggest r12,or r22 freon type. is this a easy procedure or does it take a ac person? the problem is it not cooling to full...
It's R-22 and you need to be licensed to handle it, if you're not a A/C service technician or fimiliar with charging an A/C system, then it is best to have a Coleman Service Technician to charge it for you.
Aug 29, 2010 | Coleman Mach 15 Air Conditioner
Roof air not cooling, what is the correct freon to add r22?
On the outside of the unit on the cover,there is a nameplate rating that should tell you how much and what type of freon is in it.
Jun 29, 2010 | Coleman Mach 15 Air Conditioner
Air conditioner does not cool
May 04, 2010 | Coleman Mach 15 Air Conditioner
Recycling to soon?
sounds like the unit is low on freon. it will need to be serviced so the leak can be fixed then recharged.
Jun 01, 2009 | Coleman Mach III Air Conditioner
Coleman tsr rooftop airconditioner
NEED A FREON RECHARGE AND MAY POSSIBLY HAVE A FREON LEAK
STEVE'S APPLIANCE
516-300-3249
Apr 05, 2009 | Coleman Mach 15 Air Conditioner
Compressor tries to turn on but cant.
Try changing out the start up and run capacitors for the compressor.
Jun 24, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach III Air Conditioner Logo
965 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
