The kneading arm in the bread machine not moving, and is properly snapped into place in the bread machine
Http://www.breadmakerguru.com/search.aspx?s=tr900
This site has bands/belts for breadmakers. I am buying my new paddle for the tr900s breadman pro from there. Perhaps your belt is broken? I personally have never replaced one, but it should not be too hard. Make sure you unplug the breadmaker before opening it up at all.
Try running the breadmaker with no pan in it and see if the paddle shaft turns at all during the cycle. Also, the paddle will not turn at all in the first 30 minutes of certain cycles, like the whole wheat. This is stated on the time chart of the instruction manual for this model.
Hope this helps!
WestHof
My bread machine is Zojirushi Model: BBCC-S15
The kneeding arm will not come out to clean and not working properly, bread did not mix.
The unit will not knead the mixture.. Help... the paddle moves easily on the shaft, and without the bread pan the spindle moves freely as well...
I am just trying mine out for the first time. It sat without doing anything for a half hour, then started mixing. It still has a couple of hours to go so but it looks like it kneaded it all right. Don't know how the baking will come out. But is it normal for it to sit for a half hour before it starts to do anything? The manual doesn't mention this.
My paddle also wont work. The bread is not kneaded but it cooks in its unkneaded state so it is disastrous. Any suggestions please. So everything else is working apart from the kneading.
