Question about Roper REX4634KQ Electric Dryer
No heat , circulates fine, is there an internal fuse that might have blown? LuAnn
  • 5,911 Answers
If your dryer still runs, but does NOT heat, the following two links can give you advice on how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
Your problem may or may not be related to a heating element problem. There are numerous factors that can cause a dryer not to heat.
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
On a Whirlpool Duet or Kenmore Elite model, the heating circuits are located inside the dryer under the dryer drum on the right hand side. You will need to remove the lower toe panel under the door to access. The toe panel comes off by locating and removing the screws under the bottom front edge of the panel.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) may be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify any parts you may need. The heating components are usually listed under the "Bulkhead" section.
NOTE: In many cases the problem is not the heating element. The heating element has protection devices that are designed to regulate the heat and internal temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Read through the information I provided and, if you have any questions, please post back and let me know. I hope you find this information is helpful.
NOTE: If your model number is not listed on some of the websites, use the part numbers from the Sears website and use that as your search criteria. Some model numbers will not reference on some sites, but the part numbers will.
Repairclinic.com has a repair manual that you can purchase that will also help repair any Whirlpool manufactured gas or electric dryer. The part number is 1159257.
Posted on Jul 07, 2010
Why is fan control stuck on 4?
A mechanical fan/blower control that's stuck on 4 is a worn/faulty switch. The blower motor fuse could be blown or the blower motor is dead. A electronic fan/blower control that's stuck on 4 with no blower could be a blown fuse in your fuse box, the blower motor is dead or the climate control reading itself could be sending a false reading or the unit tself iis faulty.
Sep 18, 2015 | Subaru Impreza Cars & Trucks
I have a kenmore Dryer 110.76932690. Motor runs fine. Glow bar ignitor does not light. Flame doesn't come on. Changed Internal Bias Operating Thermostat still doesn't ignite. What could be other
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Aug 30, 2014 | Dryers
Dishwasher won't start
Check the internal thermal fuse in the washer. Over heating of the drying coil may have blown the fuse. Thermal protection is buitlin to prevent a fire.
Mar 16, 2014 | KitchenAid KUDC10FXSS Dishwasher
What is the problem myheater stop working in 2011 terrain
There could be several reasons for this.
The internal heat is generated from the engine coolant system and is controlled via an control mechanism which you activate by adjusting the internal heat settings.
This control could be faulty, the air circulation fan inside your cab could be faulty or it could be a simple blown fuse.
In many cases where a leaking heater system could cause engine overheating a lazy mechanic would bypass the heater function and restrict the engine coolant from circulating through the heater coils.
My suggestion is to check all the above and you should have the problem sorted, good luck.
Feb 25, 2014 | Air Conditioning and Heat for GMC Terrain
I have a 2006 Dodge Caravan and the heat, radio and wipers quit working, as well as power windows? Replaced battery and replaced a big bwd fuse, alternator? What may be causing this and is it common in...
Their is a problem somewhere and answer is the blown fuse in the power distribution box under the bonnet ,so no doubt its blown the fuse again and the answer is to find out why ,if it hasnt blown the fuse again then their is a break in the power cable to where it goes to next which is the internal fuse box so check the cable froim the big fuse to the internal fuse board for damage .
Feb 22, 2013 | Cars & Trucks
My 2000 Buick Century Custom heater/ac fan stopped working. I can feel a little heat coming through the vents so I think the heater coil and water circulation are okay. But, its cold these days, and I...
it does sound like the heater motor fuse is blown -- but if you check it and it is good ( not blown ) then it could be the heater motor itself or even the heater switch/relay. check all the wires going to the heater motor. -- try and give the motor body a little love tap,, ( this sometimes works ) and tells ya that the motor has a bad conection or the brushes are bad.
c...
Jan 01, 2011 | 2000 Buick Century
No heat
check for blown fuses relating to the a/c heating system or the blower motor for the a/c heating system.
Also, check both heater hose tubes leading to the heater core to see if they are getting hot. If they are, a possible blend door or lack of blower fan circulation condition exists.
Can you elaborate on what conditions you do not have heat?
Does pushing the 'auto' button and rotating the fan control up help?
Dec 17, 2010 | 1998 Ford Expedition
Blower is working fine Tem gauge works Just no heat car is an 06mx 5 is there a fuse I might be missing?
No fuse for heat, you may have a bad climate control or heater core...Also make sure thermostat is opening as it is what circulates the heat around
Dec 10, 2009 | 1991 Mazda MX-5
Wont heat will charchol filter have any thing to do with the prob
No, the filter is a static item and has nothing to do with the operation of the microwave oven. The filter only helps to neutralize odors when the circulating fan is running and doesn't even affect the oven air, etc.
It is possible that an internal fuse has blown and is preventing the operation of the magnatron, which is what excites the food and creates the heating action. Otherwise, it is possible that the magnatron unit has failed and will need a somewhat costly repair. You can look in the owners manual to see if there is a FAQ or troubleshooting tip section that can provide some things to try first.
My experience has shown that it is sometimes less costly for a consumer (without repair experience) to replace the oven rather than repair it, depending on the age and overall condition at the time of breakdown. I always check for the internal fuses first thou, as they are cheap and fairly easy to replace with a little bit of repair sense.
Jul 28, 2009 | GE XL1800 1100 Watts Microwave Oven
No heat
If this is a GAS dryer make sure that the igniter or pilot light has not gone out. If this is an electric dryer, check the vent to make sure it has not clogged up and prevents the air from circulating in the dryer.
Otherwise if it is an electric dryer, make sure the heating element has not blown a fuse or burnt out.
Feb 19, 2009 | Whirlpool LEQ9858P Electric Dryer
Roper REX4634KQ Electric Dryer Logo
186 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
