Question about Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
The Cozy Console Pilot flame has been off less than a hour today 07-07 2010 can we wait till the spring time to put back on or call the Gas- company?
    President:
  • 1,515 Answers
Hi, if you are saying that its off now and is it OK to leave it off until spring, yes it is. If you want it to stay off, you can also shut the gas off at the flex line that supplies gas to the unit. Just turn the small handle to the off position, this is just for added safety.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Jul 08, 2010
I've got good flame replaced Powerpile pilot won&#t stay lit
The flame sensor is not producing enough volts to hold the gas valve open for the pilot light. Make sure the SIDE of the pilot flame is touching the sensor. If it in engulfed by the flame it won't work right.
Jan 01, 2016 | Cozy Heating & Cooling
The pilot flame is about 1/3 less than what it ought to be. Normal pilot flame for this unit is about 2". It now is about 1 1/4" thus not making contact with the thermal couple which in turn...
Often times it is dirt in the pilot orifice...take the pilot apart and blow everything out with compressed air and then reassemble...
heatman101
Feb 23, 2011 | Heating & Cooling
Cozy 351A 35,000BTU unit- pilot lights intermittently. When it does light, it shuts itself off with varying time frames. (Anywhere from a few minutes to few hours) Have replaced the thermocoupler- no...
I would be inclined to look seriously at the gas valve as the source of your problem. First I would check all wiring connections and make sure there is no breakage in the insulation. It's is really hard to say with something that acts differently like that but I would make sure that your pilot flame was good and strong and the thermocouple is as centered in the flames as you can get it. I would also clean burners and pilot light . When burner is on try tapping gently on the valve and main gas line to burners,when you do this the flame shoul burn more orange or yellow and then settle back down. Sometimes you can get tiny particles broke loose and burned on out.
You can bypass the turn over switch but I would only do this for test purposes. Hope this help. Thank you.
Jan 24, 2011 | Cozy Enclosed Front Console Heater 70,000...
Cozy heater 35000 btu pilot light goes out every 4 days
The thermocouple needs to get red hot. If the pilot flame is too low or too high or if it is not pointed on the thermocouple well, it won't stay hot enough. If the pilot flame is too low, a draft caused by opening a door could blow it out. If correcting this doesn't fix it, it could be a bad thermocouple or control. The factory assembly on these heaters is not the best.
Feb 02, 2009 | Cozy Enclosed Front Console Heater 70,000...
Cozy 351A 35000 btu
You might have a slight odor of gas when the burner first ignites. Some gas does escape before it completely ignites. It shouldn't smell after 2 years of use. If you can see the pilot flame burning from the top of the heater, the heater pilot assembly is pushed over too far. The pilot fumes could be escaping in the room and cause a smell.
Dec 27, 2008 | Cozy Enclosed Front Console Heater 70,000...
When unit goes on, there is a slight odor of gas when the valve
Cozy cheapened their heaters awhile back doing away with the air shutter. Without the shutter, a little gas can seep out into the room before it ignites and cause an odor. As for the curing odor, can you see the pilot flame looking down from the top of the heater? The pilot should be well inside the exchanger out of view. If you can see it, fumes from the pilot are getting into the room causing an odor. I had to remove the plate that holds the pilot assembly and drill a new hole shifting the plate over where it belongs. It was poorly assembled at the factory. Hope this helps.
Cozy natural gas heater Mod # CLV 335A
get someone to check the gas pressure that is poss problem gas company if nat and the lp supplier can do it
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
Cozy heater
That piece that fell out is probably the pilot orifice. It goes on the end of the pilot gas line when you screw it into the pilot assembly. Don't try to light the heater without the orifice. If your thermocouple is good and the pilot flame is set properly, the control valve could be bad. Be sure to hold the knob down for 60 seconds before releasing it.
Nov 08, 2008 | Cozy Enclosed Front Console Heater 70,000...
Cozy furnace
The pilot orifice could be dirty causing the pilot flame to be too small. Unscrew the pilot tube at the pilot assembly. The orifice is inside. Remove the orifice and blow it out with compressed air only. Reassemble and see if that fixes the problem. If the pilot flame is set too low, sometimes opening a door will cause a draft to blow out the pilot. If the thermocouple is good and the pilot flame is set properly, the control valve may be bad.
Oct 22, 2008 | Cozy Enclosed Front Console Heater 70,000...
Cozy heater
I can help with part of this problem. The thermocouple is a sensor right next to the pilot flame. When heated by the pilot flame, it generates a small voltage. This voltage opens a small valve and feeds gas to the pilot. If the pilot light should go out, the thermocouple stops generating voltage. This causes the gas valve supplying gas to the pilot to shut off. I oversimplied the way it works. If this does not make sense. Google how a thermocouple works.
Oct 11, 2008 | Cozy Enclosed Front Console Heater 70,000...
Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas Logo
Top Cozy Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
jdthefixer
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
