Question about Garmin Quest GPS Receiver
Quest Battery Did your new battery have a part number???
    Problem Solver:
  • 5 Answers
A battery for a Sony Clie N610C works perfectly, everything fits and its easy work to do. Just cut the leads off of your old battery and then solder them to the Clie battery (its on a little circuit board) and then install, my Quest II now has a functioning battery 15 minutes later.
Posted on May 08, 2008
Why no power from battery to anything on my Nissan Quest?
There are large fuses to protect the major circuits. Are you sure the cable connections are clean and tight ? Have you checked the major fuses for power, and the ground connection ?
Jul 27, 2014 | 1997 Nissan Quest
95 nissan quest no power after replacing battery
Do a fault code test. You can learn how to do this here.
Oct 25, 2012 | 1995 Nissan Quest
My 1995 Nissan Quest clicks when I try to start it. The battery is brand new
Possible bad starter. have a qualified tech check it in the vehicle. its not fun pulling it out to test and find out its good. Other easier items to check are all battery connections to battery, body terminals, block and starter for corrosion and security. New battery doesn't mean its good. Good luck
Sep 05, 2011 | 1995 Nissan Quest
Garmin quest batteries
I have seen replacement batteries for the Quest GPS units on Ebay. Search for "Quest Battery" or "Quest GPS Battery". You may need to narrow your search but that will point you in the right direction. Another source is Batteryship.com. I have bought several batteries from them and have found their service outstanding.
Apr 05, 2011 | Garmin Quest GPS Receiver
2004 Nissan quest battery drain
check your alternator to see if its charging fully,i think you will find this is the cause
Feb 14, 2010 | 2004 Nissan Quest
How to change battery on my old Quest? And what type of battery do I have to bye?
I have successfully changed the battery in two Quest II units. While it may not be for some who are intimidated by the inner workings of electronic devices, it is not that hard either. You will need a small Phillips head screwdriver. Removed the back by removing the 6 small Phillips head screws on the back. Use caution with the two screws that hold the endcap for the antenna. It is not a problem if the endcap comes off, but there is a small spring holding tension on the antenna and if it pops out, it is easily lost. Handle the two parts of the GPS gently as there are wires that joining the two sections. The battery is held into the back section of the GPS with some glue but it is easily removed with gentle prying. Use a small flatbladed screwdriver to remove the plug from the battery to the circuit board. This should be all that is needed with the old battery. A new battery can be obtained from www.batteryship.com. They sell the direct replacement for the Quest and Quest II GPS units. When you go to their website, there is a list of various devices they sell batteries for. Click on GPS. This will bring up a page for various manufacturers. Select Garmin, and look for Quest. I think the battery runs around $25.
After plugging the new battery in, you may want to use a small dab of glue to secure it to the back side of the unit like the original battery. Reassemble the unit, reversing the process with the front and the back. The Quest units have a rubber sealing gasket between the two sections. Be sure you inspect that for kinks before tightening the 6 small screws. I would suggest the screws be tightened down gradually so uniform pressure will be applied to the gasket. I would tighten one screw down partially then move to the opposite side and criss-cross the unit until all screws are snug. Again, inspect the gasket for proper seating and you are done.
Jan 17, 2010 | Garmin Quest GPS Receiver
Installed new battery in 2001 Nissan Quest backwards
WOW, your lucky it didn't blow up and start the car on fire. there is probably serious damage to the entire wiring system.
Dec 01, 2008 | 2001 Nissan Quest
Do you know where you got your battery?
I have successfully changed the battery in two Quest II units. While it may not be for some who are intimidated by the inner workings of electronic devices2_bing.gif, it is not that hard either. You will need a small Phillips head screwdriver. Removed the back by removing the 6 small Phillips head screws on the back. Use caution with the two screws that hold the endcap for the antenna. It is not a problem if the endcap comes off, but there is a small spring holding tension on the antenna and if it pops out, it is easily lost. Handle the two parts of the GPS gently as there are wires that joining the two sections. The battery is held into the back section of the GPS with some glue but it is easily removed with gentle prying. Use a small flatbladed screwdriver to remove the plug from the battery to the circuit board. This should be all that is needed with the old battery. A new battery can be obtained from www.batteryship.com. They sell the direct replacement for the Quest and Quest II GPS units. When you go to their website, there is a list of various devices they sell batteries for. Click on GPS. This will bring up a page for various manufacturers. Select Garmin, and look for Quest. I think the battery runs around $25.
May 30, 2008 | Garmin Quest GPS Receiver
Quest Battery Problem
Mar 25, 2008 | Garmin Quest GPS Receiver
Garmin Quest GPS Receiver Logo
82 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
