Phillips fr 965 power shuts down how do i replace fuse
4 Suggested Answers
robotek
  • 1512 Answers
SOURCE: where is the fuse on
Hi Hibbs8829
Generally fuses are located on the PCB attached to the power transformer terminations. In some instances the only primary fuse may be a thermal fuse located inside the power transformer that may have failed. This one you cannot see from the outside. They are replaceable, but you will need to get into the transformer somewhat to sort it out. Other than that, there are often fusible resistors and circuit protector devices on the PCB. These can be a little difficult to find if you don't know what you are looking for. Good luck
regards
robotek
Posted on Jul 15, 2008
Whitenoize
  • 11 Answers
SOURCE: does the phlips fr 965 have a fuse
If the unit was purchased in the UK, then yes it will have a fuse witht the following specs:
BS1362 5 amp, A.S.T.A or BSI approved type
Otherwise, I would suggest that you bring it to an authorized repair shop.
Posted on Mar 23, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have Phillips home theater
It's not a fuse. Fuses don't self-heal allowing another try.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Posted on Jun 11, 2011
How do I connect a Philips FR 965 digital
http://www.p4c.philips.com/files/f/fr965_00/fr965_00_dfu_nor.pdf Here ya go.
Oct 01, 2014 | Audio Players & Recorders
Code to remote for a phillips fr 965 surround
0283,0288,0280. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 22, 2014 | Televison & Video
Fr 965 won't work with fiber optic
Check for dust blocking the sockets on the fibre optic ports.
Try a different optical cable.
If it's not working then maybe the old receiver is past it.
Sep 13, 2014 | Audio Players & Recorders
Philips fr 965 wont stay on
It is shot, Kiss it good buy, Repair will be verry costly, Just go end get a different one, End not anouther (Phillips)
Nov 28, 2012 | Philips Fr965 Stereo Receivers
I have Phillips home theater system model FR 965. When I turn the power on it powers up for a few seconds and then shuts off. I have done some searching online and found advice saying that it may just be...
Jun 11, 2011 | Philips FR965DHT Receiver
Does the phlips fr 965 have a fuse
Feb 28, 2009 | Yamaha HTR-5730 Receiver
Where is the fuse on a Philips FR 965 AV receiver
Hi Hibbs8829
regards
robotek
Jul 15, 2008 | Philips Audio Players & Recorders
Phillips 64" PTV Issues
sounds like vertical problems see if you have bad solder connections then get back to me
Nov 02, 2007 | Philips 50P8341 50" Rear Projection...
 Grubhead
Grubhead
