Iput a password in my bios and forgot it i need to know how to reset it wut jumper to i shortout
    Sergeant:
  • 201 Answers
You just need to remove the battery. If it fails or you have a new Laptop contact the manufacture this is the best way.
Posted on Jul 07, 2010
Hello, My name is Vahe and I have got the following problem, I have forgot my BIOS password and I can't to turn on. Laptop model Toshiba satellite A200-13M. So I have got some solution to delete...
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 02, 2011 | Toshiba (K000002020) Motherboard
How to reset my forgot bios password acer aspire 4315
plug off your bios battery, and plug in again it can reset your bios password
Jan 04, 2011 | Acer Aspire 4315 Notebook
Lenovo n500 forgot bios password
Hello, If you forgot your BIOS password,do not worry, you can reset your system back without requesting a BIOS password,Simply unscrew your laptop and get the motherboard of your laptop, locate the CMOS battery on the motherboard and remove for sometime for the battery to discharge say 4-10minutes,or better still if you can locate the jumpers for the BIOS and reset it,the BIOS password will be removed.It is the battery that keeps the BIOS chip alive by suppling it power,if power is not supplied to this chip,then the information on it will be lost. So, remove the battery for some minutes or reset your BIOS jumper on the motherboard WISH YOU THE BEST.
Nov 22, 2010 | Lenovo 3000 N500 Notebook
Hi I forgot my password for toshiba satellite 205 cds , for bios . What I can do ? Please HELP Emanuel
You can reset bios password with 2 method.
(1) open back cover of laptop then find motherboard .Pull cmos cell from motherboard for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherboard named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Dec 25, 2009 | Toshiba Satellite A205-S4617 Notebook
Where is the jumper on a motherboard for dell latitude d430 any help plz
http://support.dell.com/support/edocs/systems/pe2650/en/sm/jumpers.htm
That page explains what jumpers are and where they're GENERALLY located. Each motherboard is different. There are usually some abreviations near the jumpers that let you know what it is that they're for. You need to be a computer guru to understand a lot of them. I'm assuming you've locked yourself out of the system bios and forgot the password. The picture in the link above should show you what that jumper might me labeled as.
Nov 05, 2009 | Dell Latitude D430 Notebook
How can i reset my bios password for an acer aspire laptop?
IF YOU KNOW THE BIOS PASSWORD YOU CAN GO TO BIOS AND CLICK ON CHANGE PASSWORD AND IF YOU FORGOT THE BIOS PASSWORD YOU NEED TO OPEN THE SYS. AND ON MOTHERBOARD THEIR IS A SMALL JUMPER THAT SAYS BIOS JUMPER ON IT YOU NEED TO REMOVE IT AND PUT IT IN PRONK 2 &3 AND RESTART THE SYS. AND THEN AGIN TURN OFF THE SYS. AND PUT THE JUMPER BACK TO PRONK 1 & 2 AS IT WAS EARLIER. AND IT WILL REMOVE THE BIOS PASSWORD.
Oct 25, 2009 | Acer TravelMate 2300 Notebook
Forgot password for bios setting
For this issue if you need to fix it with your self you need to follow the instruction from me. First you need to open your unit. Locate where the CMOS battery located.
The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is.
If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
Oct 08, 2009 | MSI K8MM-V Motherboard
Forgotten bios password ,can boot but not enter bios.
It is bios password.
Now if you forgot it then you have reset your bios settings.
For that you have to open back cover of laptop.
Then find motherbord pull CMOS cell from motherbord for 10 minutes then put again to it's position.
Then it not ask for password.
Thanks.
Oct 03, 2009 | Fujitsu Siemens LifeBook E8010 Notebook
I forgot the security password
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user password
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Aug 08, 2009 | Acer Aspire 5580 Notebook
Need help forgot password for HP Compaq NX7330
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
Please rate me .
Thanks .
Jul 29, 2009 | HP Compaq nc6320 Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
