Motor will not run - Washing Machines
  • eric bosman
    eric bosman May 11, 2010
    ? machine brand and modelnumber will be helpful
  • 52 Answers
Rollcutter, timer switch may not be switching on. If it is and power is present at the motor terminal, it could be the capacitor (starting capacitor). Faulty cap (open or short) will not kick start the motor to create torque and phase angle displacement with the main winding.
If however the switch ok, cap ok and still it won't run, could be the bushing or bearing at the end plate of the motor. loose bushing will not run the motor, you'll just hear a strong hummming sound.
Good LUCK
Posted on Apr 29, 2008
Room fan operates continually
the capacitor is correct for the motor
all it does is supply an over voltage burst to start the motor turning, then to keep it running while the switch is on
if the capacitor was faulty in the original motor then the motor will burn out as that over voltage is not there but the current to run the motor is so the motor over heats and burns
as to the constant running it is important to check how you attached the wires to the new motor as you may have a power wire direct to the motor instead of through the switch control
May 14, 2016 | Televison & Video
04 goodman furnace model GMS8 ciculator blower wont stay on gas fires and runs but high limit trip because of no air from blower any ideas bad motor or control module
You need to check the motor amp draw against the spec tag on the motor. If the motor has power to the motor wires it's either the motor or the run capacitor.
Nov 17, 2014 | Heating & Cooling
Motor does not run properly
What motor are you talking about the fuser motor, paper draw motor, the finisher motor, the transfer motor, the drum motor, the developer motor, corona wire transfer cleaning motor. I can go on.
Replacing developer and toner has nothing to do with the motor running,
Aug 06, 2014 | Sharp AR-5320 Black and White Copier
Have a kenmore stove, and a code of F93 is coming up. What is the solution?
F90
F91
F92
F93
F94
F95
If lock motor runs:
1. Test continuity of wiring between EOC and lock switch on lock motor assy. Repair if needed.
2. Advance motor until cam depresses the plunger on lock motor switch. Test continuity of switch contacts. If
switch is open replace lock motor assy.
3. If motor runs and switch contacts and wiring harness test good, replace the EOC.
If lock motor does not run:
1. Test continuity of lock motor windings. Replace lock motor assembly if windings are open.
2. Test lock motor operation by using a test cord to apply voltage. If motor does not operate replace lock motor
assy.
3. If motor runs with test cord check continuity of wire harness to lock motor terminals. If harness is good replace
the EOC.
Door lock motor or latch
circuit failure
AS YOU SEE THE F93 CODE REFERES TO THE DOOR LATCH MOTOR
Jul 19, 2011 | Kenmore Ovens
Necchi Model 535 FA - Replaced drive belt, after running machine for approximately 5 minutes, machine locks down with motor running, motor pully burns plastic belt into.
The motor is running.That is confirmed that motor is fine.But the wires from motor has to be checked.the motor connections are getting short and this is causing the plastic belt to burn.Check the motor as well as its connection.
thanks.
Jun 05, 2010 | Necchi Sewing Machines
Cant get running
computer problem??
Apr 14, 2010 | 1998 Dodge Ram 1500 4WD
My blower motor will not start. it hums and gets very hot. i can spin the wheel with no resistance gmp075-4
Assuming you are spinning it when the motor is humming, if the motor runs after spinning it it could be the run capacitor (replace) or open/broken start winding in motor(need new motor). Humming should indicate the motor is getting proper voltage. If motor does not try to run by spinning then open run winding in motor (replace motor).
Aug 30, 2009 | Heating & Cooling
Blower motor inop
Run 12 volts directly to blower motor to see if motor will run, if it does, than its blower motor resister thats bad, if it don't run than its blower motor motor thats bad. Most likely its the resister, common problem.
Mar 28, 2009 | 2002 Dodge Intrepid
Dishwasher motor won't run.
This motor has motor start relay behind the control panel
Wires to the mortor:
BU-W run from motor start relay.
Y wash (forvard).
GY drain (reverse)
W-V neutral.
Dec 08, 2008 | Dishwashers
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
