Question about Dymo DateMark Date/Time Stamper
My dymo datemark has PRESET is flashing. I've
My dymo datemark has PRESET flashing. I've preset using paper clip (and hear beep) but nothing happens. Also have removed all 5 battery's and then reconnected but PRESET is still flashing.
5 Suggested Answers
SOURCE: My Dymo DateMark won't print.
open the back cover where the batteries are and press the pinter reset button
Posted on Sep 04, 2008
SOURCE: dymo datemark
Posted on Nov 05, 2008
komguy
  • 2306 Answers
SOURCE: How do I reink the Dymo DateMark Stamp
You have to remove the ink roll door, on the front left near the bottom. Pull the roller out with a tweezers, add a few drops of ink to the roll and re-install. No matter how careful you are, you will get some ink on your hands...
Posted on Jun 22, 2009
komguy
  • 2306 Answers
SOURCE: my dymo datemark stamp says
To reset you press a toothpick in the little hole on the left side in the back. If you have more errors, you can go to the dymo website and download the manual and see troubleshooting tips.
Posted on Jan 28, 2010
How do I get my radio to work after I changed my battery. I have the radio code. It is a 2004 Suzuki forenza
Hello there
I found this in a suzuki forum
After connecting the audio security system to the battery, "CODE" will flash on the display.
Enter the proper security number into the unit, using the preset buttons No. 1 through 8.
For example, if the security number is "1234":
Press the preset button No. 1. "CODE" will disappear and "1 --- " will appear on the display.
Press the preset button No. 2, and "12 -- " will appear.
Press the preset button No. 3, and "123- " will appear.
Press the preset button No. 4, and "1234" will appear and flash three times.
The audio system will function and will transfer to the radio. If the incorrect security number is XXXXX into the unit, "Err" will appear followed by "CODE" and there will be several audible beeps. If this happens, repeat the security entering procedure beginning with Step 2.
Hope this helps.
If code doesnt work then it is dealer, sorry.
Sep 24, 2014 | Cars & Trucks
My dymo datemark stamp says "reset" but we have no idea how to do it?
Take off the back cover and insert the tip of a pen or paper clip in the little button between the 3.0 volt battery door and the AA batteries. It is "printer reset" around the little hole. This should work. It works unless something is wrong with the ribbon of letters that can get stuck. I'm trying right now to get my to reset using this solution (that has worked previously) but it is not. So it is a **** shoot!
Jan 28, 2010 | Dymo DateMark Date/Time Stamper
I`ve entered the code i was given for my philips bmw business rds PH7850V1303828 (code given was 8396) but nothing happens! am i missing something?
8396 is the correct code for that Serial Number.
Here are the Code Entry Instructions
Philips DC785/24E BMW Code Entry
After switching on the unit the display will show ' CODE - - - - '.
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the fourth digit
Followed by pressing the ' > ' rocker key.
The set will now operate.
Oct 02, 2009 | Philips Car Audio & Video
DYMO DateMark has P.Reset flashing, how do I reset?
Open the battery compartment and use a paperclip to push the printer reset button
Jul 08, 2009 | Office Equipment & Supplies
How quickly do the AA batteries run down in the DYMO Datemark. I just started using a new one this morning and have stamped maybe 50 times and have now received the flashing p.reset
Mine usually last at least 6 months. But I am careful to lean it back slightly to make sure It's not touching the switch on the bottom, and I only use fresh energizer batteries.
Jul 02, 2009 | Dymo DateMark Date/Time Stamper
P reset keeps flashing and won't print
Jun 30, 2009 | Dymo DateMark Date/Time Stamper
Radio presets?
select radio station then select which number you want to preset station to and press and hold until you hear the unit beep,also preset station will flash once aswell as the beep,station should be preset into your headunit,goodluck.
Nov 29, 2008 | Pioneer Car Audio & Video
Cn you tell me how to unlock a radio for holden barina 2000. I have the code but not the radio manual??
Press AS button until you hear a beep.
If code is 1234 use preset button 1234 and enter as follows:
Preset button 1 - Press twice
Preset button 2 - Press three times
Preset button 4 - Press four timess
Preset button 4 - Press five times.
Depress AS button and hold until radio comes on.
Thats straight out of audio book.
Steve
Nov 17, 2008 | Car Audio & Video
JVC RX 809V home reciever
Most times it goes like this:
find your station by manually searching the frequency. When found, press the memory button and in your display the word memory will flash. than press the number you want it stored under and hold it pressed untill the flashing stops.
Other option:
once station is selected, press the preset number and hold it untill you hear a beep or, if the number flashes on your display, it stops flashing.
often you have the possibility to store aprx 10 presets on 1 band, by seleting the band you get new presets for each band, geeting in total 40 preset possibilities.
Let me know if this solved your problem.
Aug 08, 2008 | Audio Players & Recorders
Feb 20, 2008 | Dymo DateMark Date/Time Stamper
1,185 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
