Question about Copystar CS-1510 Copier
Error codes E70 and E71 appeared and won't clear
The above error codes appeared on the copier window and it cannot be cleared. The copier remains inoperable. Prior to the codes appearing, the top feeder would pull papers in crooked even though they were lined up perfectly in the feeder tray.
What do E310 mean on a panasonic copier 7722
Posted on May 05, 2011
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
May 05, 2015 | AEG Washing Machines
Aeg lavamat 63613 error code E70
Family error code E70 is shown to the customer. In service mode could be: E71 or E74
Dado
May 04, 2015 | AEG Washing Machines
Copystar cs1510 showing error e70 please help
The E70 its a troubleshooting original placement and memory errors:
1. Remove originals and replace them in the original table when the "E70" or "E71" errors display.
2. Remove originals placed on the original tray and allow the copy job from the plate to complete when the "E72" error displays.
3. Remove originals remaining in the original table when the "E90" error displays, indicating that the memory is full. Press the button with a "%" sign on it, labeled recall, to print the copies of the originals that have already been scanned. When printing completes, place the remaining originals back into the original tray and press "Start" to continue copying.
Hope helps.
Apr 18, 2011 | Copystar CS-1510 Copier
Washer says f26 and won`t spin the clothes out. is there anything i can do?
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Cancel twice.
The above procedure is the specified way by whirlpool technicians to clear the error code.
Feb 02, 2011 | Washing Machines
My range top is showing me E codes and I cannot get it to turn off
Range/Stove/Oven Fault Codes starting with an E
If an error code appears in the cook mode window
Your oven is equipped with an extremely reliable and accurate electronic control. On the rare occasion that something occurs that causes a malfunction, an error message will appear in the oven selector window.
Some errors (E1, E9, E11, E12, and E13) must be cleared by turning off the oven at the circuit breaker and then turning it back on. When an error remains displayed steadily in the off position, after attempting to clear the error, a service call is required.
Jan 26, 2010 | Kitchen Ranges
ERROR MESSAGE ON RICOH BLACK AND WHITE FT3713 ERROR E70
Waste toner is full. Remove cleaning station, empty waste hopper, and run "SP83" to clear code.
Apr 22, 2009 | Ricoh FT3713 Copier
Error code 4H
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Apr 15, 2008 | Sharp AR-5316 Advanced Digital Imager...
Flashing error code
Dec 20, 2007 | Toshiba e-Studio120 Copier
Copystar CS-1510 Copier Logo
260 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
