Question about Dishwashers
Waste pipe leaks and needs replacing not sure how to do it.
  • 10 Answers
I have had the same problem with my own and also repaired a friends unit which was doing the likewise. I consider that you have to be reasonably handy to perform this replacement.
Firstly you will need to remove the bottom drawer and dry out the flood sensor. Turn the unit off at the wall power outlet before you touch anything! You need to pull the drawer out fully and then activate the tabs on the left and right side at the bottom front of the drawer to move in move it out further and off the tracks.
Make sure you have some towels on the floor in front of the unit. Once you have the drawer out lay it on it's right side on top of the towels. There will be an amount of water still in the unit which will likely drain onto the towels as you do so. Now you will be able to see into the drawer cavity, preferably with a torch, and also see the flood sensor on the rear left hand side. You should also notice a fair bit of water in the bottom of the cavity. As you've made sure the power is off, you can mop up the water.
The plastic cover over the flood sensor can be gently removed by pressing down and sliding it to the right. Once the cover is off you can again mop up the excess water before using a hairdryer to fully dry the flood sensor out. Don't put the hairdryer too close to the flood sensor, just let the warm air slowly dry things out over a 10-15min period.
You can only get a replacement hose from an authorised parts supplier. This is due to the narrow diameter of the hose and the couple which joins the pump under the drawer. Before you throw the old one out, make sure you remove the small rubber valve. It would appear to prevent backflow into the pump and is not supplied with the replacement.
I didn't totally remove the clear housing from the motor assembly, but was able to remove it part way and gently open it enough to get the old hose out. In order to more easily complete the fit of the new hose, I would recommend carefully removing the whole unit from the wall cavity. Make sure you disconnect the inlet hose, power and drainage hoses under your sink. This allows the unit to move freely from the cavity without damaging anything. There are four securing tabs inside the bottom drawer cavity which need to be removed to do this. (All quite clear in the instruction manual).
If you are at this stage I would also recommend installing the 'retro fit link support'. It is much more practical and robust when compared to the plastic one the originally came with the unit. It has a metal rod and a mount that fits into the corner of the draw cavity. Makes much more sense than the plastic rod. Mine broke anyway when I had reassembled the unit so I had to as a matter of course.
Hopefully this assists you
Posted on Jul 10, 2010
How to replace a Garbage disposal
If you buy a similar model from the same manufacturer, you can leave the sink fittings in place. Unplug the power and disconnect the waste pipe. Undo the bayonet fitting securing the waste disposal unit to the sink fitting. Fit new unit to sink fitting, reconnect waste pipe and power. Run the unit with plenty of water to check for leaks. Job done.
Dec 04, 2015 | Garbage Disposals
Sewer waste pipe replacement
plastic or croc? earthen ware? whats the material?
Jan 14, 2013 | Mountain Plumbing Products PVC Pipe Deluxe...
Moen 84913 B.R. sink taps. Installed two weeks ago. leaked, replace whole plastic assembly with steel, still leaking at the place where the waste assembly connects to pipe. Help Plumber is costing a...
make sure trap and so on so forth ie:is not forced into position or in a bind ,cut to proper length, the proper od & Id of pipe and flange and nuts with proper gaskets are all being used.Start all joint connections before aything is tightened into place
Nov 05, 2010 | Moen 24 In. Towel Bar...
Leaking sewer pipe
Depending on how many pipes you have connected in the run from the toilet to the concrete pipe, I would replace all of it with plastic pipe and a new soil pipe if I could find one, if not put the plastic in the soil pipe and pour a concrete patch to fix the hole. Without seeing what you have there, it is hard to say for sure. But cast iron is not used much these days and a job to fix, cut, seal, repair, most are replaced. Hope this helps.
Jun 01, 2010 | American Standard 2860.334 Enfield Two...
I thought my macerator toilet must be blocked as it wasn't emptying in the bowl and when I flushed again the water (and waste) filled more into the bowl and leaked out of the top of the macerator spilling...
Typical saniflo costs about 500 quid incl vat from plumbase, prices vary according to what you need it to do.
It keeps making noise becasue the pump is still trying to get rid of the water inside.
it can't get rid of the water most likely because their is a blockage in the waste water pipe.
if possible follow where the waste pipe runs to. if it goes in to a loft or somewhere else VERY COLD there is a good chance that it has frozen somewhere along the pipe.
If you are tying to pump the toilet waste vertically (upwards) then as soon as you turn the power off to the saniflo, the waste will fall back down and in to the toilet - or over the top in your case, sorry!
You might want to accept the inevitable and get a bucket and start removing the waste water from the bowl. Make sure that you have rubber gloves and I suggest goggles and something protecting your mouth - in case you get splashed.
Easiest solution, is to remove the excess waste water, turn off the saniflo, pour some bleach in to the toilet bowl, then cover the bown securley with cling film to keep the rank smell at bay.
Other wise, start tring to follopw the waste water pipe and warm it up, either by directly or indirectly (warm air gun) or by warming the area around it.
Personall;y i am using the easy option. the cold werather won't last forever, but can you use a toilet elsewhere in the meantime.
In the meantime, Saniflo claim about 15 years as the lifespan, but i have never know a saniflo to make it past 3! they are not ideal, but may be your only option.
consider whether you could get a proper toilet waste pipe put in, as it WILL save money in the long run...
Hope this helps a little bit.
Mark
Jan 08, 2010 | Saniflo & Saniplus& Macerator Pump
Zanussi front loader leaking
Most likely you have a pump shaft seal leaking you can buy a new pump at this site. You may remove the pump and clean with pool muratic acid, but it is very caustic you would have to put pump in the acid bath in a metal pan that you don't mind using it and it will eat all the organic buildup from the pump. However it may leak worse as the organic material may keep it from leaking too much. So I suggest you use the pump, if you use mueratic acid it is highly toxic so read directions on using it and were air mask and rubber gloves while using it then rinse off with clean water. You should put water hose in the drain pipe and tunrn on the water to test the drain pipe as well. this will make sure the drain pipe is fine. Look at the hoses near the clamps as this is where holes develop on the water pump hoses.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=Zanussi+front+loader
Sep 05, 2009 | Washing Machines
My master bathtub is leaking
Yes the weight of someone in the tub plus the water can push the tub down far enough to cause the leak.
Unscrew the flange in the tub that holds the drain to the tub. Get some plumbers putty and make a bead to fit between the tub and flange.
Make sure the rubber gasket is clean ..use a bit of plumber's putty on this as well. Get an assistant to stand in the tub while you snug things up.
Snug it up tight.... replace if the threads are stripped as you said.
Plus if your house is less than a year old, I'd talk to the contractor/builder if possible about warranty work...most reputable builders will cover their work for the first year.
Jun 22, 2009 | Lefroy Brooks Bath Waste Trap for Exposed...
Coffee not coming out of the front taps, coffee & waste beans both ending up in the waste tray, can you please advise thankyou. model type 889
I had the same problem. The pipe that delivers the coffee brew is plugged, therefore, the brew leaks back in the waste tray. You need to take the top cover only. Then you will see a silicone hose. You need to pull the hose out of the head pipe. You can remove easily the head pipe as it snaps on the pipe that delivers the brew. What I did was to run the descaling program. Then inserted a thin stiff wire during the cleaning process and gently pushed the wire a few times to remove the obstruction. You have to be careful. Once the obstruction is cleared steam or liquid will come out of the pipe with some pressure. Then stop the cycle and run it again once the head pipe and top cover are replaced. Although there are no electrical wires visible when you take the top cover you need to be careful and wear rubber gloves and goggles. This worked for me and it was probably due that the machine was not used for sometime and the coffe brew plugged the delivery pipe. Good luck
Mar 01, 2009 | Krups Orchestro 889 Espresso Machine
Waste trap under bath leaks
put the putty under the flange where it makes contact with the inside of the bath, push the flange to the bath & tighten nut underneath. Trim off excess. Have an overflow pipe [not intergral] make sure the top & bottom of the collar have rubber seals
If the whole lot is plastic there may well be a leak down & along the thread of the waste.[it comes from the o/flow pipe collar] Silicone the thread and tighten nut. make sure it's dry first - silicone & water do not make a happy couple
Jan 26, 2009 | Lefroy Brooks Bath Waste Trap for Exposed...
Anti flood device needing reset
pull the dishwasher out and tilt it forward to reset..worked on my electrolux.
Jul 06, 2008 | Zanussi Dishwashers
Dishwashers Logo
93 people viewed this question
Top Dishwashers Experts
Owen Barnes
