Question about Renault Fly 1:32 5 Turbo Slot Car - Rothmans #11 Rally Costa Brava 1985
My turbo is realy realy loud wen excelarating u can hear it befor u see the van help its a renault trafic
    Problem Solver:
  • 15 Answers
Hi
The turbo may have a split hose causing a loud whoosing (only way I can describe it!) noise. If the noise is a screeching noise it will be the bearings in the turbo.
Does the Trafic have any blue smoke coming out of the exhaust? If so this would point to the turbo being the culprit. If you have a loss of power this would be a split hose.
If the noise is only when the engine is under load, then a again I would be looking for a split hose.
Best of luck.
Posted on Sep 03, 2010
Did the immobiliser on the 2006 renault trafic van have a fuse
the door has a little light thing it squeeze when close.. might not be squeezing all the way. pull the door skin off. need a new starter
Mar 24, 2015 | 2009 Renault Trafic 1.9dCi
Knocking coming from front suspension 2008 Trafic LWB Crew,130k
Just check the front stabilizer links and the stabilizer bushing.
May 02, 2014 | 2009 Renault Trafic 1.9dCi
Renault forum
big cable on the starter
Apr 01, 2014 | 2009 Renault Trafic 1.9dCi
Renault trafic lwb
Sorry we don't have that.
Jan 10, 2014 | Cars & Trucks
Renault trafic tiptronic/auto gearbox
sound like problem in the shift module and shift motor in shift module.
Jun 16, 2013 | Cars & Trucks
Renault traffic van that has no power until turbo starts to boost. Some times when i labour the engine at low revs the glow plug light will come on too? Any idea's?? Thanks
i've got trafic 100dci 2001 year-had poor exceleration upto 2000 revs then turbo cut in,also at speed-mainly uphill the power would start to pulse(like small jerks forward)until it ran out of steam-80ish,changed egr valve-didn't fix it! then tested air flow meter and found figures incorrect,so replaced,also tested the tubo rod(down the back of the engine -visible with air filter housing removed)this was very stiff,so used wd40 to clean then spray oil to lube and worked the rod backward and forward until it moved freely.put all back together and that was it-back to normal-hooray!! have to point out that the van will not rev past 3700 revs when it is loaded-it has a load sensor,unloaded or partly loaded it will rev to I think about 4100 revs(don't quote me on that though) do hope this will help whoever and God bless
Aug 15, 2011 | 2006 Renault 181
Are renault trafic vans just total balls of **** please be honest turbo went , turbo changed , now abs light and service light coming on and if i drive abovr 60 mph glow plug light comes on what a ball of...
you just got a bad egg mate most of those egines are fine sure nissan and opel use the same engine in there vans. you probly need a set of glow plugs they are very easy to fit and not to pricey.
Dec 10, 2009 | 2006 Renault 181
Renault trafic 1.9 dci new turbo but lights on dash still on stop
This is a problem with the onboard management computer. It probably wasn't reset by the mechanic when the new turbo was fitted. You'll need to take it to someone with the correct diagnostic equipment to get this fault erased. Avoid Renault dealerships. They'll charge anything from £80 to £400 to clear an error. Best find someone independent.
Apr 29, 2009 | 2006 Renault 181
Renault Fly 1:32  5 Turbo Slot Car - Rothmans #11 Rally Costa Brava 1985 Logo
597 people viewed this question
Top Renault Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Renault Toy Expert? Answer questions, earn points and help others
