Question about Gateway (330A6AB0003) Sound Card
I have a gateway notebook and i had my pc cleaned and the guy must deleted my sound program becaue my pc has no sound what can i do :(
  • 487 Answers
Hi, Go to control panel, system, then hard ware and device manager, check your audio is installed correctly, if not will be high lighted with a yellow ?; if so click the + and right click audio and update driver fom there. If not possible do a search on google for your driver, down load and install. Hope this helps, regards p.s always re boot after installing a driver.
Posted on Jul 07, 2010
How to restore factory setting on gateway model mt6705
Step 1:
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate. Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files. It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen Click the "Start" icon in the lower-left corner of your Windows 7 home screen. Click "All Programs" in the Start menu, then click "Gateway". Click "Gateway Recovery Management" to open the Gateway Recovery Management program. Click the "Restore" header, then click "Restore System To Factory Default". Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes". Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart. When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes. Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer. Your computer will reboot. After the computer restarts you will need to configure Windows 7 with your personal preferences. b> Recover at Startup Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program. Click "Restore System From Factory Default". Click "Next" to begin the restoration process. The process could take anywhere between 30 and 90 minutes.
Feb 25, 2013 | Gateway MT6705 Notebook
Mouse scroll issue on gateway nv53
Do a system recovery of your computer and bring it back in time before this occured.
Apr 18, 2012 | Gateway NV5378u Notebook
Gateway mx3228 laptop loss audio and wireless drivers do you guys know where to get them?
These should work for your notebook:
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=3119
Notebooks that have the number 32XX usually all run the same standard drivers.
Aug 14, 2011 | Gateway MX3228 Notebook
My notebook is to slow
Try the following programs to help clean up your PC and get it running like new.
  1. http://www.pcdecrapifier.com/ ( PC Decrapifier: removes pre-installed manufacturer software)
  2. http://www.revouninstaller.com/ (Revo Uninstaller: removes and scrubs programs)
  3. http://www.piriform.com/ccleaner (CC Cleaner: cleans registry and unwanted fragment files)
Hope this helps!
Mar 14, 2011 | Gateway M-7315U Notebook
Previously I posted that the notebook is almost out of memory. The alert actually says "almost out of disk space". What is the best solution?
Move Pictures, Music, Movies to an external USB hard drive or burn to DVD. Uninstall unused programs and make sure your recycle bin is empty.
Oct 19, 2010 | Gateway MX6912 Notebook
I own a Gateway mx3416 Notebook. I have a booting problem. To start it, I need to start it and close it immediately, then start it again for it to boot. It also gets really hot. But the fan is working....
check your start up menu and see how many programs you have running on start up . sounds like you have too many start up programs going all at once it may be a matter of setting some programs to not start on start up .
Apr 08, 2010 | Gateway MX3416 Notebook
I have a gateway 6010GZ laptop it turns on and the cd drive spinns but thats it
turn on the power , tapping delete to bring up the BIOS
on the
main page look to see if the hard drive is being
detected everything that is in the computer ( main comp-
onents ) can be seen in the BIOS goto the boot tab make
sure the detected HDD is
booting up first not the optical drive , when finished press
F10 hit yes to save and see if the computer will boot up
I have 4 Gateway notebook computer , they are very good notebooks however they are notebooks and notebooks are
prone to needing repair tweaks constantly every once in
awhile the sound just stops working like if you switch from headphones to speakers , all Gateway notebooks come with
a reinstall drivers utility , Goto start/programs/gateway recovery center from that utility you can reinstall drivers programs and
many other default setups . there is only 3 things that can make
a computer not turn on 1. the hard drive 2. the video card 3. the
RAM , in BIOS you will see which one of these components are
not working .
Feb 11, 2010 | Gateway Computers & Internet
Very slow and always error
Start--> Programs-->Accessories-->System tool-->Disk clean up click choose the option and click ok after that one dialog box will open check all the options and click delete it may help your computer
If u have more than one anti-virus programs i will recommended that u use only one program that will make your computer slow
your computer should be slow becaue u have too much stuff in your hard drive
Download CCleaner and scan the computer and recovery files it may help you
Best Of Luck :)
Oct 11, 2009 | HP Computers & Internet
My mx3412 laptop has no sound after clean xp installation
Play with the audio Control under System settings . go to www.altavista.com type your model system or contact Gateway . be prepaired for a Repair .............. I hope you got insurance on this or it will be costly
Jun 02, 2009 | Gateway MX3416 Notebook
Hard drive for gateway MT 6451 notebook
Open "my computer" and highlight the C drive, which is basically the hard drive, at the lower left it will tell you the initial size of the hard drive and the amount if space you have left. If you don't have much space left, then you may consider a new and bigger hard drive. You can also free up some space by deleting any unused programs and running a disc defrag and disc clean up from the accessories category in the start menu.
Jul 08, 2008 | Gateway MT3705 Notebook
Computers & Internet Logo
143 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
