Question about Whirlpool Dryers
I need to replace dryer belt, 1/4 inch width and 92" long. I have opened the top of dryer and removed snapped belt, but do not know how to install new belt.
  • 1 more comment
  • Jeff Rockwell
    Jeff Rockwell Jul 07, 2010
    What is the MODEL NUMBER?
  • jmuzic Jul 09, 2010
    whirlpool estate TEDS680Eq2
    Whirlpool estate TEDS680EQ2
  • 5,911 Answers
Thank you for posting your model number. Installing a new dryer belt for this dryer involves the following steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch conector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt (if required) and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Roper and refer to diagram H.
Replacement parts (if required) can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also inlcude helpful exploded view diagrams that can help you locate and properly indentify the parts you may need.
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
Posted on Jul 09, 2010
Testimonial: "Thank-You. You solution was easy to follow and to the point. Made the at home repair go smoothly and fixed it the first time."
Replace seal around tumbler
unplug the dryer, pull out from the wall 6 inches, remove the screws at the lint filter, use putty knife to pop the clips at the seam between the top and front(one on left front and one on right front and an inch or two in) , remove the 1/4 inch hex head screw one on left , one on right, tip front forward, unplug the door switch, remember where the wires went, lift the front panel off. Remove belt by reaching under drum and grasp the idler pulley and pull it to the right and slip the belt off the motor pulley, use belt to lift the drum and pull out from cabinet. Remove old felt. do not get adhesive on you it is hell to get off. Use disposable gloves if possible. put glue around the tub, install the new felt, the fold face toward the back so that you can see the stitching. Allow 15 minutes for the adhesive to set up. Reinstall the drum, make sure the ridge of the drum is seated to the rollers in the back, put belt on the line where it has been riding and run hands around the belt making sure it is not twisted and the ribs are facing the drum. install the idler pulley in to the slot in front of the motor, pull belt through the idler pulley, pulley idler pulley to the right and re install the belt to the motor pulley. Re install the front of the dryer by inserting the clips on the inside of front in to the square holes on the cabinet front edge, re install wires for the door switch, the ones you remember where they went, put the screws back in to hold front panel, snap the top back down, put the screws back in at the lint filter area, Done! Wait about an hour before you run it to allow the adhesive to fully cure. These instructions are for most Whirlpool, kenmores made by whirlpool, roper, and kirkwood dryers. If this is not what you have contact me. Good luck.
Feb 04, 2014 | Kenmore Dryers
Tip
How to Install a belt
Unplug the dryer and take it outside.
Step 1: Remove the filter
Step 2: Remove 2 screws from filter chute on top of dryer
Step 3: Pull top towards you on each side slightly to raise it
Step 4: Remove 2 screws inside the front panel
Step 5: Unplug the lid switch using small screw driver
Step 6: Raise up the panel 1 inch then remove it
Step 7; Remove the drum
Step 8: clean it up and lube the roller & idler
Step 9: Remove the filter chute and clean it
Step 10: Place the new belt (341241) around the drum with
the ribbed side towards the drum surface making sure it is not twisted.A twisted belt will be ruined quickly.
Step 11: Use belt to help you place the drum back in the dryer.
Step 12: Make sure the rollers are in the groove and the felt is not tucked under.
Step 13: Insert the idler into the floor beneath the motor puller and raise up on it. Then loop the belt through the idler and onto the motor pulley.
Step 14: Turn the drum a bit by hand making sure the belt is on track and not twisted.
Step 15: Replace front panel
Step 16 plug in lid switch
Step 17 Snap down the top install the screws to the filter chute and shove the filter back in.
Step 18: Give it a dry run fer a sec to make sure it works well before throwing any clothes in there.
Step 19: Grab a cold one. You deserve it!
My Roper dryer Home Movie
on Jul 26, 2012 | Roper Dryers
Hotpoint tcl770 belt split
all you need to do is remove front panel pop the top off remove the two screws on the in side pull the panel up. Now you have access to dryer changing the belt is a pain if you have big hands but they give you room to get one of your hands in there
Nov 16, 2011 | Washing Machines
What type of dryer belt does Roper REX4634KQ take?
The part number is 341241 it could be purchased from your local appliance parts store on online at;
repairclinic.com
apdepot.com
partselect.com
apwagner.com
Sep 08, 2011 | Roper REX4634KQ Electric Dryer
The drive belt broke
Hello there and thanks for cfhoosing fixya
Here is a listing of the belt diagrams and a part number for you ok?
Belt, Drive
Item # 529597
img-descriptiontab-on.png img-repairgurutiptab-off.png Dryer belt. This is the most common belt used on Whirlpool, AMANA Kenmore, Kitchenaid, Roper, Estate and other dryer brands. The belt is flat, 92-1/4 inches long, 1/4 inch wide and has 4 ribs and 3 grooves. It replaces many other belts, including some with 5 ribs and 4 grooves.
img-descriptiontab-off.png img-repairgurutiptab-on.png See our dryer belt diagram to see how this belt should be installed around the motor and idler pulleys.
Watch Video
Order now and choose FedEx 2Day or FedEx Overnight shipping and this item will ship out today - or it's FREE!
$11.20 Quantity:
In Stock
Feb 05, 2011 | Amana NGD5400TQ Dryer
I need to replace the belt in my GLER341AS2 model Frigidaire dryer. How do i open up the dryer to do so?
Unplug the dryer and using a 1/2 inch pait scraper locate the spring loded clips holding the top down to the front of the cabnet. They are located about one to two inches from the front corners of the dryer.
Lift the top and rest it on the wall behind the dryer.
Looking inside the dryer locate the screws holding the front panel to the cabnet and remove the screws.
Mark the wires to the door switch and remove.
Remove the front panel.
Go behind the dryer and remove the small rear panel near the bottom of the dryer.Observe how the belt is attached to the pulleys.Release the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go to the front of the dryer and grab the belt on the top of the dryer drum. Holding the belt lift the drum straight out holding the drum with the belt.
Check to see if all the rollers are in good shape and rotate freeley. Oil if needed.
Check to see if the teflon gliders located on the front panel that hold the drum are in good shape. Replace if needed.
Vaccum the inside of the dryer.
Put the new belt over the drum and line the drum up and install back into the dryer.
Put the front panel back on and reinstall the two screws.
Replace the door switch wires.
Make sure the grooves on the belt are flat to the dryer drum
Put the top down and go behind the dryer'
Locate the belt.
Pinch the belt and insert it under the tention pulley and slide it over the motor pulley. Make sure the belt is positioned straight and located where the old belt was positioned on the drum.
Jan 03, 2010 | Frigidaire GLER341A Electric Dryer
Belt
The top must be lifted and the front must come off so you can slide the new belt on. When that is done in the back you will see a panel to be removed. Slide the belt back and install it around the pulley on the motor. When you are done put it back together and wala. I hope this helped you out.
Nov 24, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool gas dryer model # lgr7646eq3
put back back on with top off remove screws in top corners of front panel remove bottom panel and screws holding blower/lint screen housing on remove door springs remove screws on bottom corners of front belt is probably lying in bottom
Sep 03, 2008 | Whirlpool LGR3624JQ Gas Dryer
Dryer belt replacement
Take the top panel off by slideing a putty knife about 2 inches in at the front and releasing the tabs. remove screws from top of front panel after top removed. also remove 2 screws from inside of front panel on both sides about 4 inches down screwing back into front panel. pull front off and slip belt through opening. Feed belt around drum and put tension on the idler spring release onto belt. reassemble unit.
Aug 09, 2008 | Frigidaire AEQ7000ES Dryer
Changing the belt on Frigidaire GLER642
ok here we go facing the drier take a putty knife come about 1-2 inches from the edge and push in should feel a spring clip depress in lift one side then the other look inside on the front panel and remove the two 5/16 inch screws grasp the front and snap it off give it a good tug then your ready to go be sure to un plug the drier and slide it out from the wall so you can tilt the top back before removing the front don't forget my 4 boxes and make sure the idler pulley is on the belt the the belt goes around the drum around the motor pulley then you pull the idler pulley back and put the belt on top of the idler pulley let it back against the belt to keep the belt tight you do not have to remove the drum for this can all be done from the front
Jan 10, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
178 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
