Question about Brother CS-8060 Computerized Sewing Machine
Attempted to sew fabric that was too thick and heard a loud pop...now machine will not sew...seems jammed...is it worth fixing?
  • 4 Answers
Yes you might have jammed it, its a great mechine I would fix it.
call 303 770 6321
AAAA TEVA
Posted on Jul 07, 2010
I sew thin leather w/Janome MC4000 using leather needle. Want to try thicker leather but not damage machine. How thick will this machine take?
Be careful sewing thick materials with a domestic machine. Even though a lot of machines are supposedly able to sew thick leather & fabrics, it could damage your machine in the long run. If you value your machine, you might want to find a second machine (used mechanicals, older Singers, etc., probably work better for this purpose) to sew thick fabric. Save your nice primary machine for more conventional uses.
Dec 13, 2015 | Sewing Machines
My top tension is off. It was factory set for 5. I checked needle size, bobbin tension, thread, and for any build up of fuzz. I have a White Jeans machine. If I turn the top tension dial to 7, the bot
Sandra,
If the needle jams when sewing over thick items, it may be you have a dull needle? Not all machines can hem blue jean material without a hand to help the flywheel around, through the doubled over seams.
Additionally, when sewing the basic two pieces into one piece, start with the presser foot ON the fabric about a half inch sewing in reverse first, backing up to the fabrics edge and then proceeding forward through your fabric.
Fabrics too heavy or too light, are the common issues with home and commercial sewing machines.Knowing your machine and how to operate it; will get you through these "issues" when sewing.
Cheers, Happy New Year!
Kelly
Embroidery Services
San Diego, CA
Jan 01, 2015 | White Sewing Sewing Machines
Fabric not feeding
Check for jams on the bottom feed, if you do have a jam that could be why it's going slow. Or you may be using to thick of fabric.
Sep 20, 2012 | Sewing Machines
My sewing machine stops sewing and thread gets jammed underneath the fabric
Change your needle, and retread properly. then make sure you are holding the threads when you start a seam.
Sep 05, 2012 | Bernina Sewing Machines
Sewing machine motor jams when I sew thick fabric
a part of the computer is malfuctioning, & needs to be checked
try a new needle
rethread the machine using every thread guide
clean under the needle plate & in the bobbin area for loose threads & lint
Mar 19, 2012 | Sewing Machines
This is the 2nd time I have had to buy a new bobbin case base for my Bernette. I can't figure out what the heck I am doing wrong. It will jam and then after awhile it no longer wants to sit in...
That sounds like a horizontal bobbin case held in by a magnet like the Janomes have now: if so, then yes, I understand your frustration as I've replaced it on my Janome 1600P twice, always when I try to push the machine with sewing denim hems, it just won't hack it, the case will dislodge, then the needle strikes it and it jams up, again and again and again. However, my machine was serviced last year and the mechanic fitted a longer finger that holds the case down and it did fix the problem. So have you spoken to a Bernina dealer and voiced your dissatisfaction with it? Maybe they need to look at an after market fix too.
Otherwise, only other option is really to change the machine; I now use my trustly old Singer 20U when I need to seam heavy thicknesses as it can handle the heavier weight fabric okay.
Oct 21, 2011 | Bernina Bernette 75
Jams up when attempting to sew, making loud noise. Thread mass under fabric when able to cut loose from machine.
Thread jams underneath usually are caused by top thread tension issues. Things to check:
top tension discs are clean and no thread traces caught in there, tension is set to medium number usually 4 or 5 and that the top thread is running freely from the thread spool, correctly thread through the tension discs, and down to the needle. Lower the pressure foot and pull the thread from just above the needle; it should feel firm resistance if under tension correctly.
As you've had a good jam up, good idea to now remove the bobbin, needle plate and bobbin holder (refer to your manual if you have never done this before) and clean out the hook area well, look for any fine thread remants and brush out any lint etc. Oil the rotary hook area as per your manual. Now reassemble, and rethread everything again checking that the bobbin thread is clicked into the tension spring and that the top thread is through the tension discs correctly.
Also, pop in a new needle, flat shank to the back, then try again.
Good luck with your machine.
Mar 14, 2011 | Brother SE-270D Computerized Sewing...
Machine jamming up
it could be a problem with the motor, you might need to see a repairman
Jul 30, 2010 | Brother XL-2600I
Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
Oct 14, 2009 | Husqvarna Huskylock Computerized 905
Machine stops sewing when I hit a thickness
it may be that your motor belt needs tighening or the belt may be damaged - you can check belt and adjust tension yourself once side cover is removed.
if you are sewing thick seams and the needle is resting on the seam as you begin to sew you may have to help the machine to get started. if the fabric is not thick it must be belt tension.
scott.
Jun 17, 2009 | PfaFF Hobby 4260
Brother CS-8060 Computerized Sewing Machine Logo
113 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
