Question about LG Art Cool LA121CNP wall/window Air Conditioner
LG LAN125HV mini split won't turn off
The thermostat is set at 82, but even when the room temp is 76 and dropping, unit keeps pumping out cold air. I know there is a circuit board in the indoor unit, but there is also a circuit board in the outdoor unit as well. How do you pin-point the problem without spending a ton of money?
Speed boy
  • 76 Answers
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
manhandy
  • 146 Answers
SOURCE: where to install packaged piston on 4 ton 13 ser
it goes high pressure line evaporator coil if it call for it see instruction it will say.
Posted on Jul 07, 2009
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
LG neo plasma air conditioner does not blow cold air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 04, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
The unit after running for ten minutes blows hot air inside the house
Service your unit completely and then check the following. 1. Thermostat setting must be minimum +3 degree from your temp. 2. Check room temp sensor 3. Check your out door unit fan motor. (If the outdoor fan runs with less rpm the compressor will get cut off by overload protector)
Dec 13, 2010 | LG LS-L1210CL Mini Split Air Conditioner
I have a 18000btu LG mini split heat pump installed about 1 year ago in vacation home. In heat mode the unit cycles on and off when room temp is within 2-3 degrees of set point. Cycle on time varies...
Hello.I think they are on to something with shortcycling on temp sensor.I think it should be sampling the return air instead of (inside coils ?).A 2*f dead band use to be built in (factory installed) to thermostats to prevent on/off, but not sure in this case.Try a new sensor location(return air) and see if anything changes.
Oct 26, 2010 | LG LS-L1210CL Mini Split Air Conditioner
I have a split system model ls-k2464hl the remote works but will not turn on the unit.The unit will force run but only in cold
It sound like a defective receiver pcb. Have this professionally checked. I take the time to help, so please rate me!
Jun 15, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
May 02, 2010 | LG LA185HV Split System Air Conditioner
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
LG Art Cool LA121CNP wall/window Air Conditioner Logo
326 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
