Question about GE Profile Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22MIS
I've replaced the mother board three times. The las time was eight months ago and now it seems like it's going again. ge Model# PFS22MISBBB Thanks for your help.
Sea Breeze
  • 4654 Answers
SOURCE: FREZZER IS COLD FRIDGE IS NOT
OK, Sounds like we have a problem with the defrost. Need to unplug and lets remove the rear panel and examine the defrost heater, It has a glass tub around it so it will be easy to see if its burned out. WR51X10101 Defrost Heater if you need to change the defrost heater it would be a good idea to replace the defrost thermostat also. Part number WR50X10054 Defrost thermostat. Let me know if I can be of more help. And please rate my solution, Sea Breeze
email appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
http://appliancepartseast.blogspot.com/
Posted on Aug 12, 2009
dmftrucker
  • 1922 Answers
SOURCE: GE model GSS22JEMDWW. Replaced the compressor six
check the RTX overload on the compressor body its bad and trying to start the compressor
Posted on Dec 25, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ge model GDL20KCSABS refrig portion went to 50
It may not be your main board this time. Let me do some study on your design. I need to find out if you have a auto damper or just what so please communicate before you rate as it may thake some study through the morning for me to home in on the cause. I will be back soon, Sea Breeze
Posted on Feb 03, 2010
  • 291 Answers
SOURCE: I have a ge profile fridge model # PDS22SHRBRSS needing help
Yes, you have to cut the wiring as the instructions stated. Not all the models have to have wiring cut, so read carefully to see if yours is one that needs to have the wiring cut. If it is not, then you have another problem, and you will have to let us know what the origional problem was before you replaced the board. If your model requires cutting, you may have damaged the main board by not doing this. Unplug the refer and follow the instructions carefully and test to see if it works. Good luck, Appliance Specialists.
Posted on Feb 04, 2010
  • 59 Answers
SOURCE: I have a GE fridge, it is a GSH25JSRFSS model,
Sometimes you can call GE and get help but most times not if the year warranty has expired. I personally have never found any problems other than the board itself just having a bad relay or a circuit blown off the back. Thunderstorms are hard on them too. Below is a link for the model unit you asked about.
Main Board
Posted on May 21, 2010
Testimonial: "THANK YOU VERY MUCH"
GE Refrigerator wont cool past 48 degrees
there are no problem in the coil try to check the capacity of the refrigerant maybe it is less thats why its not cooling and double check the mother board maybe it is jammed.
Apr 21, 2013 | GE Refrigerators
Fluctuating Freezer and Refrigerator Temperature
check the freezer evaporator thermistor on the top left corner clipped to the evaporator,if its not 16k ohm when at 32 degrees in a glass of ice water after 4 minutes it will defrost too many times and cause this issue,you need to unplug the J1 connector on the mother board in the rear behind the cover and check terminals 4 & 5 un the plug,not on the board though
Feb 07, 2013 | Refrigerators
3 year old side by side hotpoint. 3 months ago freezer frosted up & would not cool. Repair person replaced heater & mother board worked until about 1 month ago. Frosted up again. Repair person...
This is the part that is bad....it is cutting off the defrost too soon...
http://www.partselect.com/PS1017716-GE-WR50X10068-Defrost-Thermostat.htm?SourceCode=5&ModelNum=hss25gft
or Click here
heatman101
Aug 02, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
GSS25KGMB CC side by side GE fridge not cool
The main control board is going bad . This is the electronic board behind the 8 x 10 inch panel , on the back of the refrig . Your relay on the compressor is ok .
Feb 20, 2010 | GE Refrigerators
I have a GE side by side ref. model # GSS22JFMC WW that is not cooling. A few months ago I replaced the defrosting element. It is not freezing up but for some reason it sometimes stops cooling. I can turn...
First this refrigerator has very low consumer rating. They are plagued with problems with very poor company backing. But without be able to diagnosis the problem in person I would say it's the mother board. And you may find that GE has a new updated board for your appliance. I would go to Amazon.com and search for your motherboard for your refrigerator and read the reviews. Some people leave some great idea. Plus it you bought this refrigerator brand new you can fight with GE to send you a new board.
Oct 29, 2017 | GE GSS22JF Side by Side Refrigerator
Ge Refrigerator stopped working
Deet, Unplug the refrigerator and the 3 pins on the compressor. Remember where the three compressor wires  go when you put them back on. Test all three pins 2 at a time with an ohm meter. You should get readings all the way around. Then test 1 pin at a time touching the other probe to the copper on the outside the compressor. Tell me what you come up with, Thanks, JT
Oct 23, 2007 | Refrigerators
GE Profile Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22MIS Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
