E-5 error code ricoh copier FT 3320 OG 743 - Office Equipment & Supplies
    Problem Solver:
  • 10 Answers
Fusion error
Posted on Jul 10, 2010
Ricoh ft 4022 photocopy machine displaying error code E-3.
cleaning requird clean properly with any quality cleaner then rty
May 17, 2012 | Pyle Office Equipment & Supplies
My machine is ricoh FT 4220. error 11 or E1
E101: Exposure lamp error
1- check the Exposure lamp if it damage replace it .
2- check the Exposure lamp fuse ( located in scanner )
3- check the Exposure harness .
and after you solve your problem you must
Enter SP5-810 (SC code reset) and press the Enter key to reset the code
Jan 04, 2011 | Ricoh FT3713 Copier
Error code E-22 in RICOH FT3713
· Scanner home position sensor failure
· Defective scanner motor
· Defective main motor
· Defective dc power supply board
· Incorrect scanner drive wire position
· Defective dc harness
· CN103 or CN105 on the main board is not correctly connected.
· FU202 on the dc power supply board open (blown fuse).
Jan 08, 2010 | Ricoh FT3713 Copier
I have a RICOH FT 4022 copier and it displays E 5 error code. It does not allow copying. I have checked the fuser unit and its ok. What could be the problem? Do I need a reset code to solve it and where do...
The E5 code is the fuser malfunction error.
E52 fusing lamp warm up error.Possible causes thermistor open,heater lamp open,thermofuse open.
E53 fusing lamp overheat.Thermistor in shortcircuit
E55 fusing thermistor open
When service call E5 conditions occur they cannot be cleared by turning OFF/ON the power switch.To reset turn ON the main switch,turn DIP switch 101-1 ON and OFF(the DIP switch is located in rear part under main supply board).,and turn the main switch OFF and ON.
Nov 11, 2009 | Office Equipment & Supplies
Ricoh ft 3713 error 54
Clean the thermistor and clear the code by turning on both dip switches on the main board, turn off the main switch, turn off the dip switches, turn on the main switch.
Mar 26, 2009 | Ricoh FT3713 Copier
Ricoh FT-4527, E541 error. I know that the hardware relating to this problem is the fuser, lamp, fuse or fluctuating voltage, but I don't know the key strokes to remove the error code after the part has...
....Nor do you have the parts. I answered you earlier today. If it were a simple fix/ adjustment I'd be happy to provide it. You need a trained technician, and only technicians will have the codes. You can find yourself in even bigger difficulty messing with service procedures that you know nothing about...cut your losses.
Mar 12, 2009 | Ricoh Office Equipment & Supplies
Error code E5 41 on Ricoh copier model 4527, or FT 4527
It is a fuser error (low warm up temp), often caused by fluctuating voltage.You have a blown fuse, lamp, or thermistor. Can only be reset in service mode after the problem is solved.
Mar 11, 2009 | Ricoh Office Equipment & Supplies
On a Ricoh FT 4415 copier, what does error ''E2'' mean?
Hello,Check out this site and see if any of these error codes can help you: http://www.copier-help.com/copier-help/
Have you checked the power fuse? Or have you looked at the incoming power circuit board. Could there be any burnt resistors, blown capacitors, or bad voltage transformers?
Check things out because many times when a machine doesn't even power on (no lights, no life) - it's usually a sign of something blown - fuses, circuit board, lamps, etc. Hope this helps.
Dec 11, 2008 | Office Equipment & Supplies
Ir 3320 error code e602-0001
I not familiar with the model of copier but the error is a Standard Canon Hard Disk Drive failure that will have to be dealt with by a technician. He will have to reformat and install new system software or go as far as having to replace the HDD.
Nov 19, 2008 | Canon imageRUNNER 2200
172 people viewed this question
jasbo
jasbo
