Question about Dayton 1hp 1725RPM 56C Frame 90 Volt Dc Electric Motor with 115 Volt Input Control # 1F798
I have dayton 6k757a 5 hp 230 volt motor for my air compressor and starts slow and blows the fuse.
  • jmulske Nov 04, 2010
    I have the same motor did the same thing turn out to the coils
    burned out. I still have the motor sell as parts.
    763-323-1930.
    thanks.
Won't start
power 120 volt cannot to supply to 230 volt, maximum correction factor for voltage is 15%
Apr 04, 2014 | AO Smith 5 HP 3450rpm R56Y Frame 208-230...
I have motor dayton model 9ncg4 now the wire is110 conected i need to conected 220 i need the diagram
I reversed start winding to reverse motor now it runs the right direction but it keeps starting instead of running smooth
Sep 27, 2012 | Dayton Wire Wheels Motor 2 HP 3450 230 V...
I had a 242-5D on a 120 horizontal driven by a 5 hp Dayton motor. I changed to a 2475N7.5 on a 80 gal vertical with a bad motor. I want to reuse the Dayton 5 hp motor. What can I expect?
Im not sure if iv;e got this straightYou had a 242running on 120 v driven by 5 hp dayton motor You have a new 80 gal tank with a bad 7.5 v motor and want to put the 5 v motor on it What was the size of the old tank if it was 60 or more you should be ok the 5 hp will have to work harder as long as you can make it fit you may want to consider droping down the blow out valve presssre spec 10 to 15 lbs depending on the size of the old tank
Nov 21, 2010 | Ingersoll Rand - Rand Type - 30...
Unit slows down ,bogs down
check the belts , if there not lose then the incoming power could be low or the motor could be going bad.
Apr 19, 2010 | Ingersoll Rand - Rand Type - 30...
I am changing from 460 V to 230 V on a Ingersol Rand Compressor motor # 32036006 and I cant get it to start it turns real slow is this supposed to have some sort of a motor starter capicitor set up ?
Recheck the way you have the motor leads hooked up, make sure they are correct. You did re connect the motor leads didnt you? You are not trying to run it on 230v single phase are you? Assuming it is a dual voltage motor, the leads will have to be re connected from hi voltage to lo voltage. Also when you cut the operating voltage in half the operating current(amps ) will double, all this info should be on the motor name plate. This motor does not use a capicitor to start it
Mar 15, 2010 | Ingersoll Rand - Rand Type - 30...
How to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
Aug 28, 2009 | Dayton Permanent Split Capacitor Motor Fan
Ir 7.5 vert 80 gal comp,..works and works good,...but upon startup,,motor sparks,....whats up with this?????
Same as all my 220v compressor motors. Contacts make and then enable (maximum) start-up current inside motor (brushes). Only flashes for a moment....startling yet normal. Hope this helps!
Jul 12, 2009 | Ingersoll Rand Type 30 Reciprocating Air...
Dayton 1hp 1725RPM 56C Frame 90 Volt Dc Electric Motor with 115 Volt Input Control  # 1F798 Logo
314 people viewed this question
Top Dayton Tools & Hardware - Others Experts
Bill Boyd
Jerry Pitts
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Dayton Tool and Hardware - Other Expert? Answer questions, earn points and help others
