All you need to do is set the machine to a straight stitch with the longest stitch length possible. One more thing that is helpful is to loosen the upper tension so you can pull the bobbin thread to gather.
If you check Searspartsonline, you can find the manuals for your machine and a schematic that should be able to show you how to remove the cover. Here's the link:
Are you receiving an error message 01-100 Cover Open message? The interlock could be dislodged or the tab that actuates it could be broken off the front cover assembly. You need to examine those areas and if either of those are the cause, replacement of those parts should repair it.
Good Morning girlsnowdog, thank you for your post! I
understand you are seeking information if the unit comes with a cover over the
dispenser light. However, the only cover on the actual dispenser is the
label-model cover. If so, the part number is 240570206. Most parts can be purchased directly from the manufacturer or through a
parts distributor in your area (part numbers may vary based on distributor). Is
this the part that you are referring to? If not, may you please be more
specific? Thank you for allowing me to assist you.
Function checks
1. Acquire the tool required to unlosen the parts. For example; screw drivers of ever size
2. Acquire the working area to perform the dismantling process. For example, a wide area desk free of obstacles materials and fluids required
3.A time to perform a technical responsibility of of delicate parts and pieces
4. Acquirign the tool box of vvarsatile tools required, also acquiring the box to places delicate parts that could get displaced in the process.
5. Begin the project with the objective in mind; for example, wanting to take out motherboard.
The motherboard is located in the system unit of the computer and is the board on which every additional expansion gadget is situated on.
processes
1. examine the entire screw areas around the system units requiring loosening in the process deciding on the tool required for the assignment.
2. all tools required are taken out of tool box and placed within close proximity of the technitian and the devuice requiring dismantlement.
3. Unscrew all pins carefully without causing damages, placing delicate gadget in safe area.
4. The system unit has the motherboard in side a compartment surrounded by covers screwed in place.
5. The covers are snaped out of place from hinge joints once the screws removed. A little pressure though required for the process.
6.The covers of the system unit removed exposes the device situated within, a larger part of which is motherboard that every additional gadget is plugged on by snap on hinges or screws also.
7. requiring to take out the motherboard requires unscrewing the buttons that keeps it firmly on the bottom area of the system unit.
8. the process requires accessible tools to reach areas within the entire board take care not the scratch any circuits or damage fuses
9. Once all screws have been taken out of the board sides by a screwdriver for unloosening.
10. carefully, take out the motherboard, remember the the entire board is heavy care should be taken not to drop.
11. The finally save every part to the computer, for later reestablsiment.
Hi, since these systems are specifically sold through Carrier and Carrier dealers, then you need to go directly through them for all parts. Please call them at the following number to order the parts or find a local dealer to order the parts needed. Monday-Friday, 8am - 5pm Eastern
Phone: 1.800.227.7437 or 1.800.CARRIER
I will recommend to do a negative post copy. Then check whether solid black or not. If not solid or blur, then the developer material might be dirty or not enough where u need to replace. If only certain area, such as top or bottom part not solid or blur, it might be caused by the roll guide also where u need to replace it. To replace developer is very simple, take out the waste toner box, unplug the connector on the developer unit, loose one screw, and u can take out the unit. On the unit, take out the 2 screws, and u can open the cover.
