I have Cabrio model #WED6400SWD That has worked good for couple, but suddenly started getting a F1 Signal. I cheked hose and strainer for water supply and everything was okay.I still get F1 signal. I push pause and start button and it works till the next water cycle. o you have suggestion.
    Genius:
  • 1,028 Answers
Suspect fill valve itself usually 1 coil open or if lucky bad connection at power terminals
Posted on Apr 19, 2008
WTW6600SW1 whirlpool cabrio washer keeps giving an F1 error, why??
The F1 error means that water pressure into the washer is out of range...the control on the washer learns the water pressure coming in from when it was brand new it is capable of learning just the water pressure to your house since it will vary from your neighbors...after it has learned what the normal pressure is if it doesnt see that normal pressure coming into the washer it will throw up the F1 error code
What to check is if water is coming into the washer from the rubber fill hoses with as much pressure as always did...things that could cause lesser pressure is; kinked/crushed fill hose,sediment built up in the filter screens inside of the water inlet valve( can be checked by turning off water and removing hoses and pop screen out from the back of washer where the hoses connect to)
If the filter screens are clear and water seems to coming from the hoses with good pressure...the washer control board would need to be replaced
GENE
Sep 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 signal what is the meaning
Pressure Signal Out-of-Range
F then 1 flashes when the control detects an out of range pressure signal.
* Check pressure hose connection from tub to machine/motor control. Is hose pinched or kinked?
* If F then 1 repeats numerous times after POWER is pressed and the pressure hose connection is not pinched or kinked, replace the machine/motor control.
Whirlpool Cabrio F1 error code - NOW A RECALL ISSUE! model # WTW6600SW2 Call Whirlpool or a repair center. The number for Whiripool is 1-800-253-1301
Hope helps.
Jul 12, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My kenmore keeps getting f1 code had it fixed and it cost almost 400 dollars and it is doing it again washer was just over a year old when this happened,gave 1200 for washer should last 10 years with out...
This problem has been found to be inherent with this model including its Whirlpool (Cabrio) and Maytag (Bravos) counterparts. It is due to the design of the water level control system, the pressure transducer, which has been integrated with the machine/motor control assembly. It has been found that issues with the pressure transducer including the pressure hose results in the flashing of the fault code F1. Air leaks and moisture in the pressure hose and lint or flashing in the air dome can result in signal error being sent to the machine/motor control assembly and hence the fault code F1 which is according to the service manual, a machine/motor control fault. You may observe that this fault code appears whenever water runs into the machine.
Whirlpool, the manufacturer of these models, has issued a bulletin regarding this issue and suggested the necessary actions in identifying the real cause of this problem and how to address it. Click on the link below for the troubleshooting and repair details.
Troubleshooting Fault Code F1 on Whirlpool Cabrio, Kenmore Elite Oasis, and Maytag Bravos Top Load Washers
Jun 17, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Have a cabrio washer. Sudden SD error
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Cabrio dryer is flashing f1. What does this
This is from a service bulletin. This may be of interest to you. There have been many problems with these machines in this area. Anyway, I sympathize and hope this helps. Best wishes.
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
Serial Numbers: CT01 – CU52
the tub.
a. Replace the control only after you have completed steps A – C above, and verified that there are no issues
Comments: - I don't know what satifaction they will give you, but you could contact Whirlpool. I don't know if it's fact, but some folks with this problem said that they were able to get the cost of repair covered in some cases, while others complained that they got no proper assistance from the manufacturer at all, so I really don't know for sure what good it will do, but it's worth a try. I'm sorry for your trouble and hope you find a good resolution to your problem. Best of luck and best wishes.
Sep 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I have been getting an F1 Signal, cannot use will start ,door loc
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
the tub.
Sep 06, 2009 | Washing Machines
F1 code on whirlpool cabrio top load
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
the tub.
Aug 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a cabrio washing machine only 21/2 yrs old and I keep
HE Top Load Washers
Models:
F1 Error Code
the tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(#$^&
Jul 26, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code
The F1 error code indicates a primary control failure or pressure signal out of range. Once the pressure hose & air dome have passed testing, the control board will need replaced. Good Luck And Please Rate FixYa!
Dec 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio WED6400SWD
probably fill valve ..one of the coils that controls flow to various dispensers may be bad an ohm meter for continuity ckd would be helpful
Apr 18, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
Top Washing Machines Experts
